AutoCAD 2007 cui file
I was so excited when I received my 2007 upgrade ( I was going from 2000i to 2007). I got everything loaded and then I tried to load my personal customized menus and it over road the standard AutoCAD menu (file, save, etc.). I can not find where these files are located.
Can anyone help me get my AutoCAD menus back?
HI,
Run the Options command and on the Files Tab and check the Customization Files setting. If the main customization file is set to your custom CUI file change it so that it points to the acad.cu file in a directory similar to the following:
C:\Documents and Settings\USERXXX\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\Support\acad.cui
If this path is already set to the acad.cui file then modify the Workspace by running the CUI command.
