Assign a value to system variable CGEOCS
aplitop
aplitop
I would need an ObjectArx method or a way to execute the GEOGRAPHICLOCATION command in a completely transparent way for the user, passing it some parameters like reference point or file, and the EPSG code, so that it assigns a value to the CGEOCS variable.
daniel_cadext
Maybe AcDbGeoData?
https://help.autodesk.com/view/OARX/2024/ENU/?guid=OARX-RefGuide-__MEMBERTYPE_Methods_AcDbGeoData
I've never used it though
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
aplitop
Thank you for your reply.
Related to the AcDbGeoData class, I found this article (https://adndevblog.typepad.com/autocad/2016/04/positioning-geographicmarker-using-objectarxx.html)  that sets up a new SRC, and I want to try the example, but this line :
AcDbObjectPointer<AcDbGeoData> pGeoData;
gives me a error :
error C2039: ‘_close’: is not a member of ‘AcDbGeoData’),
I added the following includes:
#include ‘AcDbGeoCoordinateSystem.h’
#include ‘dbobjptr.h’
#include ‘dbGeoData.h’
But it still gives the error .
Any idea what to do so that I don't get that error and I can test the example.
Thanks for your help.
Regards.
daniel_cadext
compiles fine for me.
