ARRAY Functions - disable options?
Kyudos
Advisor Advisor
Kyudos
The basic array-copy mode of the ARRAY functions is useful, but can I prevent my custom objects from being part of associative arrays?
Or failing that, what do I need to know about associative arrays such that they don't mess with my objects?
Virupaksha_aithal
Autodesk Support
Autodesk Support
One possible approach is to manipulate the selection set like making sure that selection set do not contains your custom entity while performing array command.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Kyudos
But that would prevent all ARRAY copies for my objects - I just want to disable the Associative option.
It is actually a general issue - for commands with options - you can use commandWillStart or documentLockModeChanged to get at the start of the command, but is there anyway to tell which option a user picks?
Virupaksha_aithal
Autodesk Support
Autodesk Support
For associated array, please track the system variable “ARRAYASSOCIATIVITY”. This system variable will provide the current setting in the AutoCAD regarding creation of assoc Array.
also, In general refer AcEdInputContextReactor. This reactor provided few options to track the kind of inputs user is providing in course of an command.
