Adn Utilities CSlideCtrl
Micky_SDP
Micky_SDP
Hi all,
I've a problem with the Slide.ocx in my arx in a 64 bit system.
The problem was that if I try to insert by VS 2010 the Slide Ctrl in my Dialog, my application fails because VS2010 allow me to insert only a 32 bit OLE control and my aplpication is 64 bit (it is an arx forAtocad 2013 64 bit) .
So, I would try to insert "by code" my CDSlideCtrl, but if a try to create it I don't see it in my Dialog and the crete method fail.
My code is this:
CDSlide64Bit *m_CSlideCtrl = new CDSlide64Bit();
CFile *file = new CFile(_T("D:\\Simboli\\Titolo1.sld"), CFile::modeReadWrite);
if(m_CSlideCtrl->Create(_T("my slide"), WS_VISIBLE, CRect(10,10,150,100), this,0, file,0, 0))
   m_CSlideCtrl->AboutBox();
Anyone can help me?
Thank's and sorry for my bad english..
Michele
owenwengerd
Is slide.ocx a 64-bit module? Is it registered correctly? What errors are displayed in the debugger output window during the call to Create()?
Owen Wengerd
ManuSoft
Micky_SDP
I've installed (and i Think correctly registred) 64-bit and 32 bit adn utilities as indicated by the adn guide. But th VS2010 see me only a 32 OLE Control because, I think, it is 32 bit.
So, to insert the control in a 64 bit application I try to insert it by code..
Balaji_Ram
Hi Michele,
I am glad you are already doing it right.
Here is a blog post that might clarify this topic further and hopefully help others who might search for this topic in future.
http://adndevblog.typepad.com/autocad/2012/07/use-64-bit-activex-component-from-a-net-assembly.html
Balaji
Developer Technical Services
Autodesk Developer Network
