Addon not loading in zero document state
prakash.muthu
Message 1 of 10
prakash.muthu
The .arx file not loading in startup when application started with zero document state. The same addon getting loaded on opening document. Is this AutoCAD behavior or any solution available.
Thank you.
Replies (9)
Message 2 of 10
Alexander.Rivilis
In kInitAppMsg message you cannot use document as far as AcApDocManager::curDocument() == 0 and acdbHostApplicationServices()->workingDatabase() == 0  in zero document state.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 10
prakash.muthu
The intension is not to use document in kInitAppMsg. Just to load addon arx and linked dll's in application startup.
Message 4 of 10
prakash.muthu
Still didn't get any solution for this problem. Is it AutoCAD restriction to load arx only when document in open. How about listening to app events without opening document.
Message 5 of 10
daniel_cadext
You use acedRegisterOnIdleWinMsg in kInitAppMsg, do initialization,
then acedRemoveOnIdleWinMsg inside of AcedOnIdleMsgFn if it’s not needed
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 6 of 10
prakash.muthu
kInitAppMsg not getting called when application starts with startup 2 and start mode 0. Its getting called on creating new document or opening disk file.
Message 7 of 10
daniel_cadext
I thought it's always called, how would you call acrxLockApplication, or acrxBuildClassHierarchy() and other functions?
Message 8 of 10
prakash.muthu
Not using mentioned methods.
Message 9 of 10
daniel_cadext
Pretty sure kInitAppMsg is always called, you’re just not seeing it. Try making a sample with this code
//----- acrxEntryPoint.cpp
#include "StdAfx.h"
#include "resource.h"
#define szRDS _RXST("")
//----- ObjectARX EntryPoint
class ArxTemplate : public AcRxArxApp
public:
    ArxTemplate() : AcRxArxApp()
    virtual AcRx::AppRetCode On_kInitAppMsg(void* pkt)
        AcRx::AppRetCode retCode = AcRxArxApp::On_kInitAppMsg(pkt);
        acedRegisterOnIdleWinMsg(OnIdle);
        return (retCode);
    virtual AcRx::AppRetCode On_kUnloadAppMsg(void* pkt)
        AcRx::AppRetCode retCode = AcRxArxApp::On_kUnloadAppMsg(pkt);
        acedRemoveOnIdleWinMsg(OnIdle);
        return (retCode);
    virtual AcRx::AppRetCode On_kLoadDwgMsg(void* pkt) override
        AcRx::AppRetCode retCode = AcRxDbxApp::On_kLoadDwgMsg(pkt);
        return retCode;
    virtual void RegisterServerComponents()
    static void OnIdle()
        static bool initOnce = false;
        if (!initOnce)
            acedAlert(_T("\init once"));
            initOnce = true;
    static void ArxTemplate_doit(void)
#pragma warning( disable: 4838 ) //prevents a cast compiler warning,
IMPLEMENT_ARX_ENTRYPOINT(ArxTemplate)
ACED_ARXCOMMAND_ENTRY_AUTO(ArxTemplate, ArxTemplate, _doit, doit, ACRX_CMD_TRANSPARENT, NULL)
#pragma warning( pop )
Message 10 of 10
prakash.muthu
Thanks @daniel_cadext  for the code sample.
We also using similar code. The problem is not with kInitAppMsg. The arx file bundled in packagecontents not getting loaded when opening AutoCAD with startup 2. Same code getting called as mentioned in sample after opening a document. Maybe AutoCAD behavior to load addons when document in open.
