Add a bitmap to an AcEdUIContext Menu
Anybody have experienced adding bitmap/icon image to an AcEdUIContext menu ? is it possible ? in defaultContext() OnUpdateMenu() ?
Thank you for your help.
Olivier.
Any place where you have the HMENU should
work.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5634255@discussion.autodesk.com...
Olivier.
any example?
I've tried this ,  and that didn't work. ObjectARX 2014
then, I 've read this here
There is no limit on the number of menu items, but items should contain only text.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2017/ENU/OARXMAC-RefGuide/file...
nick83
without source code its hard to say what is wrong. as i know, you have to add bitmaps to menu item in "MFC way", couse ObjectARX can just attach your menu and use it.
so, what about using CMenu::SetMenuItemBitmaps or CMenu::SetMenuItemInfo to your menu items?
