active command
active command
Message 1 of 8
active command
There is any way to know if there is any active command???
If so, there is any way to know if it is a command inside another command??
Aragao
Replies (7)
Message 2 of 8
Paulo,
Take a look at both CMDACTIVE and CMDNAMES system variables.
Fernando.
"Paulo Aragao" wrote in message
news:D9C993180A9491EE39933F45E3D6F8DF@in.WebX.maYIadrTaRb...
command??
> Thanks,
> Aragao
Message 3 of 8
Thanks for your suggestion!!
CHeers,
Aragao
"Fernando Poinho Malard" escreveu na mensagem
news:1076D02A03346F3239EB107DAEB86AE8@in.WebX.maYIadrTaRb...
> Paulo,
> Regards,
> Fernando.
> command??
> > Thanks,
> > Aragao
Message 4 of 8
Good question and better answer. But next is howto cancel an active command?
Thanks.
Luis.
Message 5 of 8
You can use AcEditorReactor::CommandWillStart(const char* strCmd)  and
acedPostCommand(const char*)
PS: acedPostCommand is an external function, so you have to declare
it:
extern
Adesk::Boolean acedPostCommand(const char* );
void
sgAcEditorReactor
size=2>::commandWillStart(const char* cmdStr
size=2>)
    // Cancel
line command.
acutPrintf
("\nEvent:
commandWillStart (%s)"
color=#808080>cmdStr
size=2>);
if
(strcmp
color=#000000>(
cmdStr,
"LINE"
face=Arial size=2>) == 0)
    acutPrintf
color=#ff0000>"\nComando indisponível"
color=#000000>);
    acedPostCommand
color=#ff0000>"CANCELCMD"
face=Arial size=2>);
color=#000000>
CHeers,
Aragao
command?
> Thanks.
> Luis.
Message 6 of 8
I'll try it.
Thank you.
and acedPostCommand(const char*)
it:
extern
void
sgAcEditorReactor
size=2>)
    // Cancel
line command.
color=#880000>    acutPrintf
color=#000000>(
"\nEvent: commandWillStart
(%s)"
size=2>);
color=#0000ff>    if
color=#880000>strcmp
color=#ff0000>"LINE"
size=2>) == 0)
color=#000000>(
"\nComando
indisponível"
size=2>);
color=#880000>
acedPostCommand
color=#000000>
CHeers,
Aragao
command?
> Thanks.
> Luis.
Message 7 of 8
Once a command is already in progress, you will be unable to use the
reactor technique.
If you have determined that a command is active you
can also use the following
call:
acDocManager->sendStringToExecute(curDocument, _T("\3\3"),
false, false, false);
regards
Mark
I'll try it.
Thank you.
it:
extern
void
sgAcEditorReactor
size=2>)
Cancel line command.
color=#000000>(
(%s)"
color=#0000ff>    if
color=#000000>(
"\nComando
indisponível"
size=2>);
color=#880000>
acedPostCommand
color=#000000>
CHeers,
Aragao
command?
> Thanks.
> Luis.
Message 8 of 8
If you're trying to prevent one command from being
used transparently, there are ways to do that.
Can you describe in a bit more detail what your
objective is?
"Paulo Aragao" wrote in message news:D9C993180A9491EE39933F45E3D6F8DF@in.WebX.maYIadrTaRb...
> Thanks,
> Aragao
