AcEdSSGetFilter Remove item from selection - Not Working
Kyudos
Advisor Advisor
Kyudos
During one of my commands I need to limit what the user is allowed to select, so I'm using AcEdSSGetFilter::endSSGet. However, even though my remove call comes back OK, the things I don't want to be selected are still selected. What am I doing wrong?
Code:
void MySelectionReactor::endSSGet(Acad::PromptStatus returnStatus, int ssgetFlags, AcEdSelectionSetService& service, const AcDbObjectIdArray& selectionSet)
    Acad::ErrorStatus es = Acad::eOk;
    if (pApp->VetoActive())
        CADManager.StartTransaction(__FUNCTION__);
        for (int i = 0; i < selectionSet.length(); i++)
            AcDbObjectId id = selectionSet.at(i);
            AcDbObject* pObject = CADManager.GetAcDbObject(id, AcDb::kForRead);
            AcDbBlockReference* pBlockReference = dynamic_cast<AcDbBlockReference*>(pObject);
            MyClass* pMine = dynamic_cast<MyClass*>(pObject);
            if (pBlockReference == NULL)
                es = service.remove(i);
            else if (pMine != NULL)
        CADManager.EndTransaction(__FUNCTION__);
(I only want to allow the user to click on block reference objects, except a specific type of block reference object - MyClass)
BerndCuder8196
This code i have tested with my custom blockreference and it will work fine:
void MySelectionReactor::endSSGet(Acad::PromptStatus returnStatus, int ssgetFlags, AcEdSelectionSetService &service, const AcDbObjectIdArray& selectionSet)
	if (returnStatus != Acad::eNormal)
		return;
		AcDbObject* pObject;
		if (acdbOpenObject(pObject, id, AcDb::kForRead) == Acad::eOk)
				service.remove(i);
				service.remove(i);
			pObject->close();
Kyudos
Even without the transaction stuff, it still doesn't work for me.
BerndCuder8196
Are you sure your reactor is loaded and endSSGet is called? What happens in debug mode when you set an stop mark at the loop with selectionSet?
Kyudos
That is basically the problem - it is definitely active, I get to the "service.remove" lines at the correct times (after clicking a MyClass object for instance), and the debugger shows that those calls return eOk. It just doesn't actually remove that thing from the selection - it is still highlighted in the interface and in still in the array when I get to my other selection handlers (e.g. in AcEdInputContextReactor::endSSGet).
BerndCuder8196
Have you tested turn off the other reactors? Maybe there is an problem. As I posted before, the code works fine in AutoCAD 2017 on my computer.
Info: service.remove doesn't work synchronized, it removes the indicies at end of endSSGet.
Kyudos
I got it to work! I took my code and moved it from endSSGet to ssgetAddFilter and analysed the subSelectionSet for the remove.
Not sure why one works and the other doesn't, but it works so I don't care 🙂
