acedInitGet - acedGetKeyword bug
mconficconi
mconficconi
in this function:
void _TryMeFunction(void)
	bool bContinue = true;
	do
		int iReturnValue = acedInitGet(RSG_NOZERO, _T("T RP RX RA R E"));
		if (iReturnValue == RTNORM)
			TCHAR acUserTyped[132];
			::ZeroMemory(acUserTyped, 132);
			// As you can test, if your choice is RP or RX (the 2 character ar not consecutive), acedGetKword return R
			iReturnValue = acedGetKword(_T("\nTry to use the right button mouse [Test/ Responde se vu Ple/ Rest in tX/ RAil/ Redo/ Exit] :"), acUserTyped);
				acutPrintf(_T("\n*** You have choice: %s ***"), acUserTyped);
				if (_tcsicmp(acUserTyped, _T("E")) == 0)
					bContinue = false;
	while (bContinue);
When the acedGetKword wait for the user input, using the right mouse button the error appear.
If the keyword is 2 char not consecutive, only the first is returned.
Using the keyoboard the keyword is always accepted.
tbrammer
You have "R" explicitly in the keyword list. I think this behavior is "as designed".  The uppercase letters must be unique.
Maybe this works as you expect it:
acedInitGet(RSG_NOZERO, _T("T rP rX rA R E"));
acedGetKword(L"\nTry to use the right button mouse [Test/responde se vu Ple/rest in tX/rAil/Redo/Exit] :", acUserTyped);
If you enter "RX" or "X" you reg "rX".
For "RA" or "A" you get "rA" and for "R" you get "R".
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
mconficconi
But registering RA e R with acedInitGet(RSG_NOZERO, L"RA R"), the acedGetKword(L"RAil/Redo", acUserTyped); with the right mouse menu, return the correct values (RA or R).
IMHO, is an error when the uppercase in acedGetKword are in different word of the same option....
