AcDbDimension - how to create or edit?
Message 1 of 9
hi everybody,
i try to edit a dimension style with the code
below.
it doesn't work. i can't open the
object.
what's wrong?
and how to create a dimstyle from new? and set all
the values?
thanks for help 🙂
chris
size=2>++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
AcDbDimStyleTable
*pStyleTable;
if(acdbHostApplicationServices()->workingDatabase()->getDimStyleTable(pStyleTable,
AcDb::kForRead) != Acad::eOk)
 return;
if(pStyleTable->has("Standard") ==
true)
 //pStyleTable->upgradeOpen();
 AcDbObjectId
newId;
 pStyleTable->getAt("Standard", newId);
 pStyleTable->close();
 AcDbDimension
*pDim;
 AcDbEntity *pO;
  if(acdbOpenObject(pO, newId,
AcDb::kForRead) == Acad::eOk)
   // Changes arrowhead
from closed filled to ArchTick
  pDim =
AcDbDimension::cast(pO);
pDim->setDimblk("M");
pDim->recomputeDimBlock();
   pDim->close();
Replies (8)
Message 2 of 9
Try this here
AcDbDimStyleTableRecord
color=#4b0082>pRec
= 0;
CString
color=#4b0082>m_dimstyle
color=#800080>"gglass"
Acad::
color=#0000ff>ErrorStatus
color=#4b0082>m_eStatus
if(!
color=#0000ff>AcDbSymbolUtilities
color=#880000>hasDimStyle
color=#a000a0>acdbCurDwg
AcDbObjectId
objId;
m_eStatus =
AcDbSymbolUtilities
color=#ff0000>::
getDimStyleId
color=#ff0000>(
objId,
"Standard",
if(
color=#0000ff>Acad
color=#a000a0>eOk
AcDbDimStyleTable
pCurT = 0;
m_eStatus =
acdbCurDwg
color=#ff0000>()->
getDimStyleTable
color=#ff0000>(
pCurT,
AcDb::
color=#a000a0>kForWrite
if(
color=#0000ff>Acad
color=#a000a0>eOk
m_eStatus =
acdbOpenObject
color=#ff0000>(
pRec,
objId,
color=#0000ff>AcDb
color=#a000a0>kForRead
if(
color=#0000ff>Acad
color=#a000a0>eOk
pDimRecord =
color=#0000ff>new
color=#0000ff>AcDbDimStyleTableRecord
pDimRecord =
color=#ff0000>*)
pRec
color=#ff0000>->
clone
color=#ff0000>();
if(
color=#4b0082>pDimRecord
m_eStatus =
pDimRecord
color=#ff0000>->
setName
color=#ff0000>(
m_dimstyle
color=#ff0000>);
if(
color=#0000ff>Acad
color=#a000a0>eOk
acedAlert(
color=#800080>"Unable to set dimension style name"
color=#ff0000>);
m_eStatus =
pDimRecord
color=#ff0000>->
setDimblk
color=#ff0000>(
"_ArchTick"
color=#ff0000>);
if(
color=#0000ff>Acad
color=#a000a0>eOk
acedAlert(
color=#800080>"Unable to set dimblk"
m_eStatus =
pDimRecord
color=#ff0000>->
setDimblk1
color=#ff0000>(
"_ArchTick"
color=#ff0000>);
if(
color=#0000ff>Acad
color=#a000a0>eOk
acedAlert(
color=#800080>"Unable to set dimblk1"
m_eStatus =
pDimRecord
color=#ff0000>->
setDimblk2
color=#ff0000>(
"_ArchTick"
color=#ff0000>);
if(
color=#0000ff>Acad
color=#a000a0>eOk
acedAlert(
color=#800080>"Unable to set dimblk2"
m_eStatus =
pDimRecord
color=#ff0000>->
setDimldrblk
color=#ff0000>(
"_ArchTick"
color=#ff0000>);
if(
color=#0000ff>Acad
color=#a000a0>eOk
acedAlert(
color=#800080>"Unable to set dimldrblk"
m_eStatus =
pCurT->
color=#880000>add
if(
color=#0000ff>Acad
color=#a000a0>eOk
m_eStatus =
pDimRecord
color=#ff0000>->
close
color=#ff0000>();
if(
color=#0000ff>Acad
color=#a000a0>eOk
acedAlert(
color=#800080>"Unable to close new dimstyle"
pRec->
color=#880000>close
pCurT->
color=#880000>close
return ;
else
acedAlert(
color=#800080>"Unable to add dimstyle to current drawing"
color=#ff0000>);
pRec->
color=#880000>close
pCurT->
color=#880000>close
delete
return ;
m_eStatus =
pRec->
color=#880000>close
if(
color=#0000ff>Acad
color=#a000a0>eOk
acedAlert(
color=#800080>"Unable to close record of source drawing"
color=#ff0000>);
pCurT->
color=#880000>close
return ;
m_eStatus =
pCurT->
color=#880000>close
if(
color=#0000ff>Acad
color=#a000a0>eOk
acedAlert(
color=#800080>"Unable to close current layer table"
color=#ff0000>);
else
acedAlert(
color=#800080>"Unable to retrieve dimstyle from source drawing"
color=#ff0000>);
Sorry for the way that copy and paste made this
look
hi everybody,
below.
object.
what's wrong?
all the values?
thanks for help 🙂
chris
AcDbDimStyleTable
*pStyleTable;
 return;
true)
 AcDbObjectId
newId;
 AcDbDimension
*pDim;
 AcDbEntity *pO;
  pDim =
   pDim->close();
Message 3 of 9
hi gary,
what a perfect code!
works fine :-))
thank you very much
chris
Message 4 of 9
hi, how this color code
FONT face="Verdana, Arial, Helvetica" size=1 color="#ff3366">
have been done?<
Message 5 of 9
Vaadake meie uudiste leheküljel:
Message 6 of 9
Message 7 of 9
No problem just let me know if you have any more
questions?
hi gary,
works fine :-))
thank you very much
chris
Message 8 of 9
hi gary,
i have another question:
how to set an other dimstyle
current?
Message 9 of 9
You need to call these two functions
acdbCurDwg
color=#ff0000>()->
setDimstyle
color=#ff0000>(
m_dimstyleId
color=#ff0000>);
acdbCurDwg
color=#ff0000>()->
setDimstyleData
color=#ff0000>(
m_dimstyleId
color=#ff0000>);
m_dimstyleId is the
ObjectId of the dimstyle you want to make current
When you are adding the dimstyle record you can use
this way because it gives you the ObjectId of the dimstyle
color=#ff0000>
pCurT
color=#880000>add
color=#4b0082>m_dimstyleId
hi gary,
current?
