Message 1 of 1
Accessing different object models from a managed application.
05:52 AM
This is a .NET sample from ADN / Research the Knowledge Base / AutoCAD
Developer Center / .NET
I tried this sample project by using VS C# 2002 or 2003. It can not be
compiled.
Errors as following:
c:\projectsarx\test\dotnet\accessingdifferentobjectmodels\objectmodelstest2\mgdarx\class1.cs(56,23):
error CS0117: 'Autodesk.AutoCAD.ApplicationServices.DocumentCollection' does
not contain a definition for 'LockDocument'
c:\projectsarx\test\dotnet\accessingdifferentobjectmodels\objectmodelstest2\mgdarx\class1.cs(61,6):
error CS0200: Property or indexer
'Autodesk.AutoCAD.DatabaseServices.ObjectId.OldId' cannot be assigned to --
it is read only
c:\projectsarx\test\dotnet\accessingdifferentobjectmodels\objectmodelstest2\mgdarx\class1.cs(62,54):
warning CS0618:
'Autodesk.AutoCAD.DatabaseServices.ObjectId.Open(Autodesk.AutoCAD.DatabaseServices.OpenMode)'
is obsolete: 'Use Transaction.GetObject instead'
Can anybody from Autodesk give a help?
I think this sample would be very valuable if it works.
Thank you.
Zhongwei Xia
