0bjectARX2024 encountered an exception error with setCurrentLayout.
mitsuru_shinohara_sx
Message 1 of 11
When AutoCAD was upgraded from AutoCAD 2017 Mechanical to the 7th generation version of AutoCAD 2024 Mechanical,
An exception error occurred in setCurrentLayout at 0bjectARX2024.
Can you tell me how to deal with it?
The processing order is as follows:
①createLayout
②setDefaultPlotConfig
③updateLayoutTabs
④setCurrentLayout
The created layout is set to the current layout (layout to be processed).
Replies (10)
Message 2 of 11
tbrammer
Can you post sample code or even a sample project that allows to reproduce the problem?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 11
The excerpted Sample code is described.
The process of creating a layout is performed in the following order:
<Ever pre-processing layout creation>
AcApLayoutManager *pLayoutManager = (AcApLayoutManager*)acdbHostApplicationServices()->layoutManager();
if(pLayoutManager != NULL){
AcDbObjectId layoutId = AcDbObjectId::kNull; //Layout ID
AcDbObjectId btrId = AcDbObjectId::kNull; //Block Table Record ID
//Generating Layouts
es = pLayoutManager->createLayout(cstrName.AllocSysString(),layoutId,btrId,pDb) ;
if(es == Acad::eOk ){
objID = layoutId ; //Layout ID
BTblReObjID = btrId ;  //Block Table Record ID
pLayoutManager->setDefaultPlotConfig(btrId);
pLayoutManager->updateLayoutTabs(); //renewal
pLayoutManager->setCurrentLayout(cstrName.AllocSysString());
//Adjusting the Layout - Adding to a Block
AcDbObjectPointer<AcDbLayout> pLayout(layoutId,AcDb::kForWrite) ; //layout
if(pLayout.openStatus() == Acad::eOk){
<From here, post-processing of layout creation>
It worked fine until I upgraded from AutoCAD 2017 Mechanical to AutoCAD 2024 Mechanical.
Past efforts include:
[Past efforts]
(1)Check the error details with "try-catch".
(2)Comment out the process that is causing the error.
(3)Run "existsLayout" and check the return value. (Check for the existence of the specified layout)
(4)Check the return value of "setCurrentLayout".
(5)Reverse the order of processing of "updateLayoutTabs" and "setCurrentLayout".
(6)Comment out the transaction processing that is performed before and after the layout creation process.
(7)Update the template to 2024.
(8)Review the AutoCAD environment (profiles, templates, print settings).
[Result]
(1)Try-catch does not confirm the error.
(2)I get an error with "setCurrentLayout" that I am processing elsewhere.
(3)Returns True (exists)
(4)Returns the unset state (zero if correct).
(5)The phenomenon remains unchanged.
(6)The phenomenon remains unchanged.
(7)The phenomenon remains unchanged.
(8)The phenomenon remains unchanged.
Please advise if there is a problem with the environment (profile, template, print settings).
Message 4 of 11
daniel_cadext
This works for me, maybe you just need to lock the document?
also you don't need the AllocSysString stuff
    static void AcRxPyApp_idoit(void)
        AcAxDocLock lock; //Added a doc lock
        const CString cstrName{ L"WooHoo" }; //Get rid of the AllocSysString
        AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
        AcApLayoutManager* pLayoutManager = dynamic_cast<AcApLayoutManager*>(acdbHostApplicationServices()->layoutManager());
        AcDbObjectId layoutId;
        AcDbObjectId btrId;
        if (auto es = pLayoutManager->createLayout(cstrName, layoutId, btrId, pDb); es != eOk)
            acutPrintf(_T("\nOops %ls"), acadErrorStatusText(es));
        if (auto es = pLayoutManager->setCurrentLayout(cstrName, pDb); es != eOk)
        AcDbObjectPointer<AcDbLayout> pLayout(layoutId, AcDb::kForWrite);
        if (auto es = pLayout.openStatus(); es != Acad::eOk)
        acutPrintf(_T("\nYahoo! %ls"), acadErrorStatusText(Acad::eOk));
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 5 of 11
I tried executing the method.
An exception error is printed on line
"es = pLayoutManager->setCurrentLayout(cstrName, pDb)"
"acutprintf" cannot be output because "autoCAD" exits due to an exception error.
The debugger seems to return eOK(0).
The content of the exception error is "An unhandled exception occurred in 0x00007FFD3033C583 (accore.dll) (in acad.exe): 0xC0000005: An access violation occurred while reading location 0x0000000000000318. "
I also tried the case where "AcAxDocLock lock;" was added to "es = pLayoutManager->setCurrentLayout(cstrName, pDb)".
Message 6 of 11
daniel_cadext
How are you running this code, is it in a command context?
is pDb the active drawing or is this a side database?
Message 7 of 11
daniel_cadext
The only other thing I can think of is calling acdbDoSetupForLayouts and acdbClearSetupForLayouts
 Adesk::ULongPtr contextHandle = 0;
 acdbDoSetupForLayouts(pDb, contextHandle);
 AcDbObjectId btrId;
 acdbClearSetupForLayouts(contextHandle);
Message 8 of 11
I interpret that the command context = executed from the AutoCAD command.
I ran it via a self-made command.
I called a method just before the code in question.
The active drawing.
Only one "dwg" file is open at runtime.
Message 9 of 11
tbrammer
Have you tried to execute Daniel's code in "pure" AutoCAD / AutoCAD Mechanical 2024? I mean without any non Autodesk modules loaded and from a small ARX project that contains his code only?
If this works the root of the problem is probably in one of the other modules. Maybe a reactor, an overrule or a redefined command.
It it doesn't work there is probably a problem with your AutoCAD installation. Try to reinstall or repair it or try it on a diiferent machine.
Message 10 of 11
We also thought that this problem could be in other modules.
However, due to the black box, it is difficult.
If we find out anything, we will contact you.
Message 11 of 11
This case has been resolved.
It turns out that there is an error in the other module.
I coordinated with the vendor and asked them to fix that module.
Now I have confirmed that it works without any issues.
Thank you very much for your advice and countermeasures.
