Announcements
Suggestion: cross sections per layer
RLivingstonB5Z5C
RLivingstonB5Z5C
In 2 of the other programs that work well with the HP MJF printer, they provide a graphic representation of the build through its cross sections. If you see the graphics below, they come from Materialize. (The other program that can make it is FabPilot)
HP seems to love software that is able to show this. I trust the MonteCarlo nest, but this graph is an extra layer of comfort that my management team wants to see.
The graphs shown below are of the same build but packed differently. You want a vertical(ish) line and you want it to be evenly distributed about the build unit. In some builds, you see large spikes, use the Slice Area values to see how large the spikes can be.
very bad buildvery bad buildbad buildbad buildan OK buildan OK buildok-good buildok-good buildok-good buildok-good buildpretty good buildpretty good buildgood  buildgood build
Replies (8)
RLivingstonB5Z5C
Similar to part orientations, if there is an orientation option that will optimize the cross section, that will work well with HP and metal printers.
wassi3
Slice your build room (Home -> Slice Parts)
View -> Show Slice Statistics
Thats maybe what you are looking for.
YESSS!
That is exactly what I am after! Thank you!
Ill tone it down.
YESS
It worked! That is exactly what I was looking for, but it is a little clunky compared to the other programs. It looks like it must be resliced every time in order to update the slice analysis.
steffen_anders_adsk
Autodesk Support
Autodesk Support
Caveat: Slice analysis currently does a blunt sum of all contours on a layer, it does NOT calculate a unification. Meaning, if you have intersecting or enclosed contours, they are still counted as if they were separate. For DLP and MJF processes that don't use offsets, this doesn't matter, but for MPBF, for instance, where multiple concentric passes along contours are common, this produces incorrect results of enclosed area.
(It does factor in the sign of the contour, though, so a proper inner contour – think "torus" – correctly subtracts from outer contours.)
Steffen Anders
Autodesk Netfabb Team
Netfabb resources: Online HelpNetfabb knowledge baseForumsHomepageYouTube
Studio53
I could see where that could be problematic.
shrenik6KA9E
Community Visitor
Community Visitor
Where you able to figure out how to do this in better way in Netfabb?
steffen_anders_adsk
Autodesk Support
Autodesk Support
This is not a concern for slice analyses called directly from 3D workspaces such as the ones for HP machines. The command works out areas correctly regardless of enclosed contours:
This still requires parts, and shells within parts, to be printable and non-intersecting.
Kind regards,
Steffen
Steffen Anders
