Simple thicken command?
frennyluv
frennyluv
I need to simply thicken my entire model so it is not becoming ultra thing when I scale it 1:3
There has been a lot going on and more than a week ago I found it somehow, I had to set either Fusion 360 or Netfabb in some beta mode or something, I think and then I had that option.
Every time I look up something on youtube these people have this 'MODEL' tab that I don't have when I look at my STL files. Why are my menu's so different? As a starter I can't follow any of these tutorials since I really need to know every baby-step to get to that command.
How do I thicken in either Netfabb, Fusion360, AutoCAD? I don't like the meshmixer one, it's slow to render and it makes edges very uncontrolled.
I really looked everywhere for weeks, that's why I decided to come here now, I hope you can help me. Thanks!
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @frennyluv,
Welcome to the Netfabb forum!
To create a thicker version of an existing part, use Generate Shell and choose Outer Offset.
To learn about generating shells, read this article in the online help: https://help.autodesk.com/view/NETF/2020/ENU/?guid=GUID-F854868E-7774-465A-A294-9082B1275492
Make sure the part is repaired and intact, otherwise you might need to get a little bit more invasive and use Extrude in Repair on selected areas for example, as well as Wrap Part or Detect/Split off/Remove Self-Intersections to deal with the latter. (Splitting off instead of outright removing them allows you more freedom and selectivity when reassembling the part. You can manually delete split-off fragments. Afterwards, use right-click > Stitch Triangles to close the seams, see https://help.autodesk.com/view/NETF/2020/ENU/?guid=GUID-D84EB5A4-166D-4356-A59A-DD84EBC5B134.)
To learn about self-intersections, read this article in the online help: https://help.autodesk.com/view/NETF/2020/ENU/?guid=GUID-9470E0A6-8137-4197-BA4E-E6B78FA4A417
Best regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online help • System requirements • Knowledge base • Forums • Homepage • YouTube
How to get Netfabb Basic: Video • Help • Download
frennyluv
Ah, there it is... Sometimes in a hurry and not practicing it right after made me forget after  the first time.
That little submenu also tricked me. When I try different things in the search bar with  'thicken'  I get all these complicated problems people had.
Thank you so much, Netfabb is the best for converting all these different file types that are out there and make them printable!!
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @frennyluv,
Thank you for the praise, I've forwarded it to the team! We're happy to hear about your appreciation.
Also thanks for letting me know what you searched for when trying to find the right tool. I'll make sure to add the appropriate keyword to the article so that future searches bring it up!
Best regards,
Steffen
Steffen Anders
