passing command line params to lua script.
I am running a lua script on Netfabb startup using following method
C:\Program Files\Autodesk\Netfabb Ultimate 2020\netfabb.exe /startluascript="D:\MyLuaScript.lua"
I want to pass a parameter to MyLuaScript.lua, like
C:\Program Files\Autodesk\Netfabb Ultimate 2020\netfabb.exe /startluascript="D:\MyLuaScript.lua" "param1" "param2"
Is it possible to send the custom command line arguments (i.e. param1, param2) and access them in MyLuaScript.lua during its execution?
Thanks.
steffen_anders_adsk
Autodesk Support
Autodesk Support
No, this is currently not supported. However, in the script you're calling, you could hard-code reading from a configuration file which you would auto-generate similar to how you would auto-generate the command-line you want to use for calling Netfabb.
Best regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online help • System requirements • Knowledge base • Forums • Homepage • YouTube
How to get Netfabb Basic: Video • Help • Download
Hello Steffen,
The parameters I want to pass to the lua are decided dynamically, so they can not be read from a config file from inside the lua.
so since the parameters are not allowed, I need to do a very very dirty workaround.
1. create a template lua script (with a special character sequence where the parameters will be replaced)
2. Create a copy of the template script in %temp% folder
3. replace the special char sequence in the lua with param string
4. run the script in net fabb
5. delete after use.
 Repeat above steps whenever needed.
I hope you provide capability of passing parameters in future releases. Smiley Frustrated
Thanks.
steffen_anders_adsk
Autodesk Support
Autodesk Support
Remember that you can read files not only of plaintext but also of JSON and XML. These formats are accessible very conveniently through objects, making reading and also writing very streamlined. Instead of replacing string sequences in an actual Lua script, you could auto-generate a new configuration file from your dynamic parameters every time you wish to run the actual Lua script. This would be more robust to debug and to maintain.
An example of reading a configuration of sorts during runtime from a JSON file is realised in the NAS scripts in the Examples folder, NAS standing for Netfabb Application Service.
Best regards,
Steffen
Steffen Anders
Agreed,
But, creating a json file at run time and accessing it in the lua isn't an elegant way either, especially if I want to access only a couple of parameters.
Command line params to the lua script would be the best way.
steffen_anders_adsk
Autodesk Support
Autodesk Support
No, it would not be the best way, not least for technical reasons:
Those command-line parameters you're requesting would be parameters not so much for the Lua script (or the Lua interpreter in Netfabb) but to Netfabb itself for which /startluascript is already a command-line parameter in its own right. Provisioning for yet more parameters that may or may not be relevant to the netfabb.exe executable would defeat the purpose as to why Lua was made available in Netfabb in the first place, automation and realizing user-individual functionality without having to wait for the next Netfabb release, among other things.
And besides, there is really only cosmetic difference between (hypothetical example, does not work, and will not be implemented)
REM launchNF.cmd:
start "" "C:\Program Files\Autodesk\Netfabb Ultimate 2020\netfabb.exe" ^
    /startluascript="path\to\startupscript.lua" %1 %2
-- startupscript.lua:
parameter1 = arg[0]
parameter2 = arg[1]
and (this does work in the Netfabb you already have, ready to go)
REM launchNF.cmd:
echo {"parameter1":"%1","parameter2":"%2"} > startupparameters.json
paramJ = system:loadjson("path\\to\\startupparameters.json")
parameter1 = paramJ:getstring("parameter1")
parameter2 = paramJ:getstring("parameter2")
so that you could use
launchNF.cmd Alice Bob
to launch the whole thing in either case.
Steffen Anders
