LUA Netfabb Inputdlg
I have a problem with Inputdlg system function in LUA Script. Function includes 3 strings and the last one is the input value displayed in window. How can I get the value? I know that LUA automation in Netfabb doesn't support input and output facilities. Is there any function to read the last string? Is there possibility to include I/O Library?Untitled.jpg
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @Anonymous,
Welcome to the Netfabb Forum!
The last string is a default value that is used when the user does not enter anything.
This is how you use it:
local userinput = system:inputdlg("Input something","Your input:","nothing to say");
system:messagedlg(userinput);
Result:
Clicking OK returns whatever is currently written in the input field, default value or otherwise. Clicking Cancel always returns the default value, regardless what is currently written in the input field.
All strings must be present, but can be empty; so, although of limited value, this would be correct syntax:
local userinput = system:inputdlg("","","");
Best regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online helpSystem requirementsKnowledge baseForumsHomepageYouTube
How to get Netfabb Basic: VideoHelpDownload
