Lattice to Fusion 360
jtomasd
jtomasd
Hi!
I want to build a lattice based body, and exported it as a parametric body so I can open it again in Fusion 360, but that option isn't enabled.
Does anyone know how to solve this?
Thx!
Sualp.Ozel
We do not have such a capability in Netfabb
What is your end goal?
Sualp Ozel, PE
Principal Product Manager
jtomasd
I can see the option, but it not enabled. I'm building a net to filter some materials, so I want to add that to my fusion model.
Sualp.Ozel
https://help.autodesk.com/view/NETF/2020/ENU/?guid=GUID-94CB75FA-84F8-4ED8-99D3-48F6E817B9E9
To export parts as parametric CAD file
Note: Export to CAD formats is available only for those parts that were loaded as CAD file and still retain their parametric data.
Note: If this export option is grayed out, it is not a parametric part and you cannot export it to SAT, STEP, or IGES.
Sualp Ozel, PE
Sualp.Ozel
you can try this (PS: I am using the latest version 2020.3)
1) Mesh to brep
2) Apply
3) export as STEP
i am not sure if it will work for your complex model , but it works for the model i show in the attached images
Sualp Ozel, PE
jtomasd
I have been trying the steps you show me, but the part always stops at 33% and shows the following problem.
steffen_anders_adsk
Autodesk Support
Autodesk Support
It looks like you're trying to BREP a complex lattice. This will not work as the BREP function in Netfabb is not set up for that.
Kind regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online helpSystem requirementsKnowledge baseForumsHomepageYouTube
How to get Netfabb Basic: VideoHelpDownload
