error code 131
error code 131
rodrigo_fariasZZEDN
error code 131
rodrigo_fariasZZEDN
Community Visitor
Community Visitor
Im trying to open .slm files in Netfabb.
.slm file from Magics software opens with no problems, showing all slices.
But when I use a .slm from Ansys Additive Prep, this error appears:
"System error (OS code 131):
An attempt was made to move the file pointer before the beginning of the file."
Didnt find anything on the web.
Thanks.
steffen_anders_adsk
Autodesk Support
Autodesk Support
Hello, @rodrigo_fariasZZEDN,
Welcome to the Netfabb forum!
That would suggest that the SLM written by ANSYS is either formally incorrect or is formally correct in a way that Netfabb's import is incapable of interpreting correctly and that what Magics writes hasn't been hitting so far for you.
Either way, without example files this would be difficult to investigate, so, I can only recommend to provide some, ideally generated from the same input data but with different software each.
In the meantime I can only suggest to try different export formats or export format settings from ANSYS that don't happen to trigger the issue.
Kind regards,
Steffen
Steffen Anders
Autodesk Netfabb team
Netfabb resources: Online help • System requirements • Knowledge base • Forums • Homepage • YouTube
How to get Netfabb Basic: Video • Help • Download
rodrigo_fariasZZEDN
Community Visitor
Community Visitor
Hello Steffen.
Thanks for the reply. Here is attached a small example, since I cant share my original geometries.
Its a small cube of 10mm side, sliced with default settings from Ansys Prep 2025R1. It generates this same warning in Netfabb if I try to load the .slm file.
In the meantime, I will try to provide a similar one from Magics.
Regards.
steffen_anders_adsk
Autodesk Support
Autodesk Support
Thank you for your files, they are on their way to investigation.
Best regards,
Steffen
Steffen Anders
