Work with CustomizationSection and WorkspaceCollection
Good Morning all,
I would like to use VB.Net in AutoCAD to check whether
certain work areas are available.
Example: User-01, User-02, User-03
I would also like to check which work area is currently
switched on, for example User-01.
If the other work areas do not yet exist, they should
be added.
The User-01 work area should become active / currently
active again.
So far I have this, but how do I add the other user 02, 03.
At the moment there is only User-01 left and how do I set
it when there are several work areas like the original ones
from AutoCAD?
Dim CuixFile As String = GetSystemVariable("MENUNAME")
Dim acCS As CustomizationSection
acCS = New CustomizationSection(CuixFile)
Dim acWSCOL As WorkspaceCollection
acWSCOL = acCS.Workspaces
Dim acWS As Workspace
For Each acWS In acWSCOL
    If Not acWS.Name = "User-01" Then
        'List of User-01, 02, 03 ????
        acCS.Workspaces.Add(acWS)
Next
'Set User-01 current
acCS.Save()
Gepaha
Code posted a long time ago in the missing jprdintprev.
I don't know if it is exactly what you want but it is a starting point.
I also didn't test it due to lack of time.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Customization;
using Autodesk.AutoCAD.Geometry;
using System.IO;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
namespace CUISAMP_2010
    public class CuiSamp
        // All Cui files (main/partial/enterprise) have to be loaded into an object of class
        // CustomizationSection
        // cs - main AutoCAD CUI file
        CustomizationSection cs;
        CustomizationSection entCs;
        CustomizationSection[] partials;
        //This bool is used to determine when to save the cui
        //If running the callForAllChanges(), only want to call saveCui at the end
        bool bSaveCui = true;
        int numPartialFiles;
        YesNoIgnoreToggle yes = YesNoIgnoreToggle.yes;
        YesNoIgnoreToggle no = YesNoIgnoreToggle.no;
        // True when enterprise CUI file is loaded successfully
        bool entCsLoaded;
        // ed - access to the AutoCAD Command Line
        // Allows us to write messages or Issue Commands in the interface
        Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
        //Default Constructor
        public CuiSamp()
            // retrieve the location of, and open the ACAD Main CUI File
            string mainCuiFile = (string)Application.GetSystemVariable("MENUNAME");
            mainCuiFile += ".cuix";
            cs = new CustomizationSection(mainCuiFile);
            string entCuiFile = (string)Application.GetSystemVariable("ENTERPRISEMENU");
            if (entCuiFile.Equals("."))
                entCsLoaded = false;
            else
                entCs = new CustomizationSection(entCuiFile);
                entCsLoaded = true;
            // Code for loading all partial CUI's listed in the main CUI file
            partials = new CustomizationSection[cs.PartialCuiFiles.Count];
            int i = 0;
            foreach (string fileName in cs.PartialCuiFiles)
                if (File.Exists(fileName))
                    partials[i] = new CustomizationSection(fileName);
                    i++;
            numPartialFiles = i;
        // Command: savecui
        // This Command saves all open CUI Files that have been modified
        [CommandMethod("savecui")]
        public void saveCui()
            // Save all Changes made to the CUI file in this session.
            // If changes were made to the Main CUI file - save it
            // If changes were made to teh Partial CUI files need to save them too
            if (cs.IsModified)
                cs.Save();
            for (int i = 0; i < numPartialFiles; i++)
                if (partials[i].IsModified)
                    partials[i].Save();
            if (entCsLoaded && entCs.IsModified)
                entCs.Save();
            // Here we unload and reload the main CUI file so the changes to the CUI file could take effect immediately.
            Application.SetSystemVariable("FILEDIA", 0);
            string cuiMenuGroup = cs.MenuGroup.Name;
            Application.DocumentManager.MdiActiveDocument.SendStringToExecute("cuiunload " + cuiMenuGroup + " ", false, false, true);
            string flName = cs.CUIFileName;
            string flNameWithQuotes = "\"" + flName + "\"";
            Application.DocumentManager.MdiActiveDocument.SendStringToExecute("cuiload " + flNameWithQuotes + "\n", false, false, true);
            // Load all the partial CUIX files, They are not loaded when the main cuix file
            // is loaded with command line version of CUILOAD
            string fileNameWithQuotes;
            ////int i = 0;
                    fileNameWithQuotes = "\"" + fileName + "\"";
                    Application.DocumentManager.MdiActiveDocument.SendStringToExecute("cuiload " + fileNameWithQuotes + "\n", false, false, true);
            String currentWkspace = "Acme Workspace";
            String cmdString = "WSCURRENT " + currentWkspace + "\n";
            Application.DocumentManager.MdiActiveDocument.SendStringToExecute(cmdString, false, false, true);
            cmdString = "RIBBON ";
            cmdString = "MENUBAR " + "1" + "\n"; ;
            Application.DocumentManager.MdiActiveDocument.SendStringToExecute("filedia 1 ", false, false, true);
        // Lisp callable function: savecui
        // Lisp wrapper for savecui command
        [LispFunction("savecui")]
        public ResultBuffer saveCui(ResultBuffer args)
            saveCui();
            return args;
        // Command: addmenu
        // This Command adds a new menu to all workspaces called Custom Menu, which contains 2 sub items
        // The Menu is first added to the Main CUI File and then added to all it's workspaces.
        [CommandMethod("addmenu")]
        public void addMenu()
            try
                if (cs.MenuGroup.PopMenus.IsNameFree("Custom Menu"))
                    System.Collections.Specialized.StringCollection pmAliases = new System.Collections.Specialized.StringCollection();
                    //pmAliases.Add("POP12");
                    pmAliases.Add("POP18");
                    PopMenu pm = new PopMenu("Custom Menu", pmAliases, "Custom Menu", cs.MenuGroup);
                    addItemsToPM(pm);
                    addMenu2Workspaces(pm);
                    if (bSaveCui)
                        saveCui();
                else
                    ed.WriteMessage("Custom Menu already Exists\n");
            catch (System.Exception ex)
                ed.WriteMessage(ex.ToString());
        // Lisp callable function: addmenu
        // Lisp wrapper for addmenu command
        [LispFunction("addmenu")]
        public ResultBuffer addMenu(ResultBuffer args)
            addMenu();
            return args;
        // Add new Items to a PopMenu
        private void addItemsToPM(PopMenu pm)
            try
                PopMenuItem pmi = new PopMenuItem(pm, -1);
                pmi.MacroID = "ID_AUGI"; pmi.Name = "Autodesk User Group International";
                pmi.MacroID = "ID_CustomSafe"; pmi.Name = "Online Developer Center";
        // Add the menu to all the workspaces
        private void addMenu2Workspaces(PopMenu pm)
            try
                foreach (Workspace wk in cs.Workspaces)
                    WorkspacePopMenu wkpm = new WorkspacePopMenu(wk, pm);
                    wkpm.Display = 1;
        // Command: remmenu
        // This Command deletes the menu added above from the Main CUI File and any
        //  workspaces that it was added to.
        [CommandMethod("remmenu")]
        public void remMenu()
            // Find Index of the desired MenuItem
            // Remove it from all Workspaces that it exists in
            // Omitting this step leaves nasty left-overs in the Workspace files
            // Remove it from the Cui files' Menu List
            try
                PopMenu pm = cs.MenuGroup.PopMenus.FindPopWithAlias("POP18");
                if (pm != null)
                        WorkspacePopMenu wkPm = wk.WorkspacePopMenus.FindWorkspacePopMenu(pm.ElementID, pm.Parent.Name);
                        if (wkPm != null)
                            wk.WorkspacePopMenus.Remove(wkPm);
                    cs.MenuGroup.PopMenus.Remove(pm);	// Deletes the Menu from ACAD Menu Group
                    if (bSaveCui)
                        saveCui();
        // Lisp callable function: remmenu
        // Lisp wrapper for remmenu command
        [LispFunction("remmenu")]
         public ResultBuffer remMenu(ResultBuffer args)
            remMenu();
            return args;
        // Command: addws
        // This command adds a new workspace. The name of the workspace to create is
        // obtained from the command line.
        [CommandMethod("addws")]
        public void addws()
            String wsName;
            PromptResult prs = ed.GetString("Enter name of workspace to create: ");
            try
                if (PromptStatus.OK == prs.Status)
                    wsName = prs.StringResult;
                    if (-1 == cs.Workspaces.IndexOfWorkspaceName(wsName)) // If the workspace doesnot exist
                        Workspace nwWs = new Workspace(cs, wsName); // Create the workspace
                        if (bSaveCui)
                            saveCui(); // Save and reload the CUI file
                    else
                        ed.WriteMessage("A workspace with this name already exists");
                ed.WriteMessage("Exception: {0}", ex.Message);
        // Lisp callable function: addws
        // Lisp wrapper for addws command
        [LispFunction("addws")]
        public ResultBuffer addws(ResultBuffer args)
            addws();
            return args;
        // Command: remws
        // This command removes a workspace. The name of the workspace to remove is
        [CommandMethod("remws")]
        public void remws()
            try
                String wsName;
                PromptResult prs = ed.GetString("Enter name of workspace to remove: ");
                    if (-1 != cs.Workspaces.IndexOfWorkspaceName(wsName)) // If the workspace exists
                        cs.deleteWorkspace(wsName); // Remove the workspace
                        if (bSaveCui)
                    else
                        ed.WriteMessage("No workspace exists with this name");
        // Lisp callable function: remws
        // Lisp wrapper for remws command
        [LispFunction("remws")]
        public ResultBuffer remws(ResultBuffer args)
            remws();
            return args;
        // Command: cuishortcut
        // This adds a Shortcut key to the CUI command.
        // Ctrl+B is used for Toggling SNAP. It gets reassigned
        [CommandMethod("cuishortcut")]
        public void shortCut()
            try
                // In here we will make a shortcut Key combination to the Customize.. command
                MacroGroup mg = cs.MenuGroup.MacroGroups[0]; // Search the ACAD Macros
                foreach (MenuMacro mcr in mg.MenuMacros)
                    if (mcr.ElementID.Equals("MM_1635"))
                        MenuAccelerator ma = new MenuAccelerator(mcr, cs.MenuGroup);
                        ma.AcceleratorShortcutKey = "CTRL+B";
                        if (bSaveCui)
                            saveCui();
        // Lisp callable function: cuishortcut
        // Lisp wrapper for cuishortcut command
        [LispFunction("cuishortcut")]
        public ResultBuffer shortCut(ResultBuffer args)
            shortCut();
            return args;
        // Command: dockf
        // Set Properties palette to float
        [CommandMethod("dockf")]
        public void dockInfoPalF()
            dockInfoPalette(DockableWindowOrient.floating);
        // Lisp callable function: dockf
        // Lisp wrapper for dockf command
        [LispFunction("dockf")]
        public ResultBuffer dockInfoPalF(ResultBuffer args)
            dockInfoPalF();
            return args;
        // Method to implement the positiioning/docking of the "Properties" window
        private void dockInfoPalette(DockableWindowOrient orientation)
            int wkB = cs.Workspaces.IndexOfWorkspaceName("Acme Workspace");
            // check to see if it exists
            if (wkB == -1)
                // if not, then see if it is called simply AutoCAD
                wkB = cs.Workspaces.IndexOfWorkspaceName("AutoCAD");
                if (wkB == -1)
                    // if not, then ok - it's something else
                    Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Workspace not found.");
                    return;
            Workspace wk = cs.Workspaces[wkB];
            foreach (WorkspaceDockableWindow dockableWindow in wk.DockableWindows)
                //if(dockableWindow.Name.Equals("Info Palette"))
                if (dockableWindow.Name.Equals("Properties"))
                    if (orientation.Equals(DockableWindowOrient.floating))
                        dockableWindow.DockFloat = DockedFloatingIgnoreToggle.floating;
                    else
                        dockableWindow.DockFloat = DockedFloatingIgnoreToggle.docked;
                    dockableWindow.Display = yes;
                    dockableWindow.Orientation = orientation;
                    dockableWindow.AutoHide = OnOffIgnoreToggle.off;
                    dockableWindow.UseTransparency = no;
                    if (bSaveCui)
                        saveCui();
                    break;
        // Command: addtoolbar
        // Creates a new toolbar called "New Toolbar", and adds it to all workspaces.
        // This toolbar contains a Toolbar control for named view, button for drawing
        // a pline, and a flyout that uses the "Draw" tool bar.
        [CommandMethod("addtoolbar")]
        public void addToolbar()
            try
                Toolbar newTb = new Toolbar("New Toolbar", cs.MenuGroup);
                newTb.ToolbarOrient = ToolbarOrient.floating;
                newTb.ToolbarVisible = ToolbarVisible.show;
                ToolbarControl tbCtrl = new ToolbarControl(ControlType.NamedViewControl, newTb, -1);
                ToolbarButton tbBtn = new ToolbarButton(newTb, -1);
                tbBtn.Name = "PolyLine";
                tbBtn.MacroID = "ID_Pline";
                ToolbarFlyout tbFlyout = new ToolbarFlyout(newTb, -1);
                tbFlyout.ToolbarReference = "DRAW";
                    WorkspaceToolbar wkTb = new WorkspaceToolbar(wk, newTb);
                    wk.WorkspaceToolbars.Add(wkTb);
                    wkTb.Display = 1;
                if (bSaveCui)
                    saveCui();
        // Lisp callable function: addtoolbar
        // Lisp wrapper for addtoolbar command
        [LispFunction("addtoolbar")]
        public ResultBuffer addToolbar(ResultBuffer args)
            addToolbar();
            return args;
        // Command: remtoolbar
        // This Command removes the toolbar added above from the Main CUI File and any
        [CommandMethod("remtoolbar")]
        public void remToolbar()
            try
                Toolbar tbr = cs.MenuGroup.Toolbars.FindToolbarWithName("New Toolbar");
                if (tbr != null)
                        WorkspaceToolbar wkTb = wk.WorkspaceToolbars.FindWorkspaceToolbar(tbr.ElementID, tbr.Parent.Name);
                        if (wkTb != null)
                            wk.WorkspaceToolbars.Remove(wkTb);
                    cs.MenuGroup.Toolbars.Remove(tbr);	// Deletes the toolbar from ACAD Menu Group
                    if (bSaveCui)
                        saveCui();
        // Lisp callable function: remtoolbar
        // Lisp wrapper for remtoolbar command
        [LispFunction("remtoolbar")]
        public ResultBuffer remToolbar(ResultBuffer args)
            remToolbar();
            return args;
        // Command: tempkey
        // This command will install a temporary override key. Temporary override keys are keys that temporarily
        // turn on or turn off one of the drawing aids that are set in the Drafting Settings dialog box
        // (for example, Ortho mode, object snaps, or Polar mode).
        [CommandMethod("tempkey")]
        public void tempOverride()
            try
                TemporaryOverride newTempOverride = new TemporaryOverride(cs.MenuGroup);
                newTempOverride.OverrideShortcutKey = "SHIFT+Y"; // Scan code for Y
                newTempOverride.Name = "Customization Override";
                newTempOverride.Description = "Customization Override";
                newTempOverride.ElementID = "EID_CUITEMPOVERRIDE";
                // Creating a override for Shift+Y (Key down) that will behave as temporary override for OSnap to endpoint (MM_1629)
                OverrideItem newOverrideItem = new OverrideItem("MM_1629", OverrideKeyState.Down, newTempOverride);
                newTempOverride.DownOverride = newOverrideItem;
                if (bSaveCui)
                    saveCui();
        // Lisp callable function: tempkey
        // Lisp wrapper for tempkey command
        [LispFunction("tempkey")]
        public ResultBuffer tempOverride(ResultBuffer args)
            tempOverride();
            return args;
        // Command: dblclick
        // This command adds a double click action for polylines (Non-LWpolylines like 2D polylines).
        // After running this command, When we double click a polyline (i.e., a non-light weight polyline),
        // the "Properties" window is launched. This replaces the original behaviour where "pedit" was launched.
        [CommandMethod("dblclick")]
        public void doubleClick()
            DoubleClickAction dblClickAction = new DoubleClickAction(cs.MenuGroup, "My Double click", -1);
            dblClickAction.Description = "Double Click Customization";
            dblClickAction.ElementID = "EID_mydblclick";
            dblClickAction.DxfName = "Polyline";
            DoubleClickCmd dblClickCmd = new DoubleClickCmd(dblClickAction);
            dblClickCmd.MacroID = "ID_Ai_propch";
            dblClickAction.DoubleClickCmd = dblClickCmd;
            if (bSaveCui)
                saveCui();
        // Lisp callable function: dblclick
        // Lisp wrapper for dblclick command
        [LispFunction("dblclick")]
        public ResultBuffer doubleClick(ResultBuffer args)
            doubleClick();
            return args;
        // Command: cuiall
        // Issuing this command will run the methods to make all changes to the UI
        // This will add the custom menu, toolbar, and RibbonElement, as well as
        // dock the Properties palette on the right side.
        [CommandMethod("cuiall")]
        public void callForAllChanges()
            bSaveCui = false;
            addws();
            addMenu();
            addToolbar();
            dockInfoPalF();
            addRibbonElements();
            saveCui();
        // Lisp callable function: cuiall
        // Lisp wrapper for cuiall command
        [LispFunction("cuiall")]
        public ResultBuffer callForAllChanges(ResultBuffer args)
            callForAllChanges();
            return args;
        [CommandMethod("addRibbonElements")]
        public void addRibbonElements()
            RibbonRoot ribbonRoot = cs.MenuGroup.RibbonRoot;
            RibbonPanelSourceCollection panels = ribbonRoot.RibbonPanelSources;
            RibbonPanelSource ribPanelSource = new RibbonPanelSource(ribbonRoot);
            ribPanelSource.Text = "MyPanel";
            // Add a RibbonRow
            RibbonRow ribRow = new RibbonRow();
            //Add the RibbonRow to the RibbonPanel
            ribPanelSource.Items.Add((RibbonItem)ribRow);
            //Create a Ribbon Command Button
            RibbonCommandButton ribCommandButton = createRibbonCmdButton(ribRow, "MyButton", "ID_CircleRad", false);
            //Add the ribbon command button to the ribbon row
            ribRow.Items.Add((RibbonItem)ribCommandButton);
            // Create a Ribbon Command Button to add to the RibbonSplitButton
            // created next. Create a new command
            RibbonCommandButton ribCommandButton2 = createRibbonCmdButton(ribRow, "MyButton", "ID_CircleRad", true);
            String strSplitButtonID = "mySplitButton_ID";
            string splitButtonName = "mySplitButton";
            RibbonSplitButton ribSplitButton;
            ribSplitButton = createRibbonSplitButton(ribRow, ribCommandButton2, splitButtonName, strSplitButtonID);
            //Add the ribbon split button to the ribbon row
            ribRow.Items.Add((RibbonItem)ribSplitButton);
            // Add the Ribbon Panel Source to the Ribbon Panels
            panels.Add(ribPanelSource);
            // Create a new Ribbon Tab Source
            RibbonTabSource tabsrc=null;
            tabsrc=new RibbonTabSource(ribbonRoot);
            tabSrc.Name = "MyTab";
            tabSrc.Text = "MyTab";
            //Add the Ribbon Tab Source to the collection
            RibbonTabSourceCollection tabs = null;
            tabs = ribbonRoot.RibbonTabSources;
            tabs.Add(tabSrc);
            //Add the Panel to the Tab
            RibbonPanelSourceReference ribPanelSourceRef = null;
            ribPanelSourceRef = new RibbonPanelSourceReference(tabSrc);
            ribPanelSourceRef.PanelId = ribPanelSource.ElementID;
            ribPanelSourceRef.ElementID = "MyElementId";
            tabSrc.Items.Add(ribPanelSourceRef);
            // Add the tab to the work space
            AddTabToWorkspace("Acme Workspace", tabSrc.ElementID);
            if(bSaveCui)
                saveCui();
        RibbonCommandButton createRibbonCmdButton(RibbonRow ribRow, String buttonName, String strMacroID, bool bCreateNewCmd)
            RibbonCommandButton ribCommandButton = new RibbonCommandButton(ribRow);
            ribCommandButton.Text = buttonName;
            if (bCreateNewCmd)
                MacroGroup macGroup;
                macGroup = cs.MenuGroup.MacroGroups[0];
                //This will add a new Command,
                MenuMacro menuMac;
                //Just using an existing identifer for the icons
                menuMac = macGroup.CreateMenuMacro("testCommandWB", "^C^CLine ", "ID_MyLineCmdWB", "My line help",
                                 MacroType.Any, "RCDATA_16_3DALIGN", "RCDATA_32_3DALIGN", "Test command label");
                ribCommandButton.MacroID = menuMac.ElementID;
            else
                ribCommandButton.MacroID = strMacroID;
            return ribCommandButton;
        RibbonSplitButton createRibbonSplitButton(RibbonRow ribRow, RibbonCommandButton ribCmdButton, String splitButtonName, String strSplitButtonID)
            RibbonSplitButton ribSplitButton = new RibbonSplitButton(ribRow);
            ribSplitButton.Text = splitButtonName;
            ribSplitButton.ButtonStyle = RibbonButtonStyle.SmallWithoutText;
            ribSplitButton.ListStyle = RibbonSplitButtonListStyle.IconText;
            String SplitbuttonElementID = strSplitButtonID; // "mySplitButton_ID";
            ribSplitButton.ElementID = SplitbuttonElementID;
            RibbonSplitButtonBehavior rsbehavior = RibbonSplitButtonBehavior.DropDownFollow;
            ribSplitButton.Behavior = rsbehavior;
            RibbonSplitButtonListStyle rsStyle = RibbonSplitButtonListStyle.IconText;
            ribSplitButton.ListStyle = rsStyle;
            ribSplitButton.LargeImage = "";
            RibbonButtonStyle rsButtonStyle = RibbonButtonStyle.LargeWithHorizontalText;
            ribSplitButton.ButtonStyle = rsButtonStyle;
            string sKeyTip = "my Key Tip";
            ribSplitButton.KeyTip = sKeyTip;
            ribSplitButton.Items.Add(ribCmdButton);
            return ribSplitButton;
        public void AddTabToWorkspace(String strWrkSpaceName, String strTabName)
            // This command adds the tab to the Acme Workspace
            WSRibbonRoot wrkSpaceRibbonRoot = null;
            WorkspaceRibbonTabCollection wsRibbonTabCollection = null;
            WSRibbonTabSourceReference wsRibTabSrcRef = null;
            try
                WorkspaceCollection WsCollect = cs.Workspaces;
                if ((WsCollect.Count <= 0))
                    ed.WriteMessage("Failed to Get the WorkspaceCollection\n");
                    return;
                for (int i = 0; i < WsCollect.Count; i++)
                    //If the name of the Workspace is "Acme Workspace" then get the WSRibbonRoot
                    if (WsCollect[i].Name == strWrkSpaceName)
                        wrkSpaceRibbonRoot = WsCollect[i].WorkspaceRibbonRoot;
                        i = WsCollect.Count; //Exit for loop
                if (wrkSpaceRibbonRoot == null)
                    ed.WriteMessage("Acme Workspace WSRibbonRoot Not found\n");
                    return;
                //Create the WSRibbonTabSourceReference from RibbonTabSource (insert tab - ID_TabInsert)
                wsRibTabSrcRef = createWSRibbonTabSrcReference(strTabName, cs);
                if (wsRibTabSrcRef == null)
                    ed.WriteMessage("Failed to create WSRibbonTabSourceReference\n");
                    return;
                //Get the Tabcollection in the Acme Workspace
                wsRibbonTabCollection = wrkSpaceRibbonRoot.WorkspaceTabs;
                if (wsRibbonTabCollection.Count <= 0)
                    ed.WriteMessage("Acme Workspace does not currently contain any Tabs\n");
                //Get a count of the Ribbons in the ribbon collection in Acme Workspace
                int intialTabCount = wsRibbonTabCollection.Count;
                // Make the parent of the WSRibbonTabSourceReference the Acme Workspace RibbonRoot
                wsRibTabSrcRef.SetParent(wrkSpaceRibbonRoot);
                //Add the WSRibbonTabSourceReference to the Acme Workspace Ribbon Tab collection
                wsRibbonTabCollection.Add(wsRibTabSrcRef);
                //Check the count of the Ribbon Tab collection verifies the new Tab was added
                if (wsRibbonTabCollection.Count != intialTabCount + 1)
                    ed.WriteMessage("Failed To add WSRibbonTabSourceReference to Acme Workspace");
                    return;
            catch (System.Exception es)
                ed.WriteMessage(es.Message);
            finally
                if (wrkSpaceRibbonRoot != null)
                if (wsRibTabSrcRef != null)
                if (wsRibbonTabCollection != null)
        WSRibbonTabSourceReference createWSRibbonTabSrcReference(String sTabId, CustomizationSection custSection)
            RibbonTabSource ribTabsrc=null;
            RibbonRoot ribbonRoot = null;
            if (ribbonRoot == null)
                ed.WriteMessage("RibbonRoot Not found\n");
                return null;
            //Find the the Tab
            ribTabsrc=ribbonRoot.FindTab(sTabId);
            // Make sure the Ribbon Tab is found
            if (ribTabsrc== null)
                ed.WriteMessage("Ribbon Tab Not found\n");
                return null;
            //Create the WSRibbonTabSourceReference using the RibbonTabSource
            wsRibTabSrcRef = WSRibbonTabSourceReference.Create(ribTabSrc);
            //Return the WSRibbonTabSourceReference
            return wsRibTabSrcRef;
        [LispFunction("addRibbonElements")]
        public ResultBuffer addRibbonElements(ResultBuffer args)
            return args;
    public class CUIStartup : IExtensionApplication
        // Used to support the saving and updating of CUI settings.
        [DllImport("acad.exe", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedCmd")]
        private static extern int acedCmd(System.IntPtr vlist);
        //Constants used frequently below
        const String WORKSPACENAME = "Acme Workspace";
        const String ACADDEFAULT = "AutoCAD Default";
        const String ACADCLASSIC = "AutoCAD Classic";
        [DllImport("acad.exe", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "ads_queueexpr")]
        extern static int ads_queueexpr(byte[] command);
        public void Initialize()
            try
                // Create and fill the new Workspace, if it is not already filled.
                bool bCreated = false;
                Workspace newWs = CreateOrGetWorkspace(ref bCreated); // ...and recreate it anew.
                if (bCreated == true)
                    // If we happened to create the workspace, then send the following commands to make sure the UI is updated immediately.
                    // UPDATECUI simply calls the SaveCUI method below.
                    // WSCURRENT sets the Workspace to our newly created workspace.
                    // The reason these must be issued via ads_queueexpr() is that AutoCAD is not yet ready to receive UI directives
                    // that update the editor - sending these through ads_queueexpr() will ensure that the request is sufficiently delayed.
                    UnicodeEncoding uEncode = new UnicodeEncoding();
                    ads_queueexpr(uEncode.GetBytes("(Command \"_UPDATECUI\")"));
                    ads_queueexpr(uEncode.GetBytes("(Command \"WSCURRENT\"  \"" + WORKSPACENAME + "\")"));
                }//if
                ed.WriteMessage("Error: " + ex.Message);
        public void Terminate() { }
        public CUIStartup()
        // This command will add the workspace if it does not exist and the UI elements.
        // If the workspace settings have been modified, they will be reset to what was
        // done by this example.
        [CommandMethod("ADDACMEWS")]
        public void addAcmeWorkspace()
            try
                RemoveAllComponents(); // Remove the workspace, if it exists...
                    // In this case, we have the luxury of having the UI ready for CUI directives.
                    // We can simply call SaveCui and
                    // directly set the WSCURRENT variable without the need to send to the commandline.
                    // Set the workspace to the new/updated workspace.
                    Application.SetSystemVariable("WSCURRENT", WORKSPACENAME);
        // This method will return the custom workspace, creating it if necessary.
        public Workspace CreateOrGetWorkspace(ref bool bCreated)
            Workspace newWs;
            // If the workspace does not exist
            if (-1 == cs.Workspaces.IndexOfWorkspaceName(WORKSPACENAME))
                newWs = new Workspace(cs, WORKSPACENAME); // Create the workspace
                // Call each of these helper methods in-turn to create the CUI content.
                addMyMenu(newWs);// Fill it with our menu's - custom and standard.
                addMyToolbar(newWs); // new custom and standard Toolbar
                // Save the changes...
                if (cs.IsModified)
                    cs.Save();
                bCreated = true;
            else // Otherwise, just return the existing workspace.
                bCreated = false;
                newWs = cs.getWorkspace(WORKSPACENAME);
            return newWs;
        // **************** Add a Custom Menu to the Workspace********************
        void addMyMenu(Workspace newWs)
            // Create a custom Menu.  This will have the BOX and PYRAMID commands as well as the User Group and Online Developer Center
            // Command entries.
            // Give the toolbar an alias name.
            pmAliases.Add("MyCustomMenu");
            addItemsToPM(pm); // Populate it with the menu entries...
            WorkspacePopMenu wkpm = new WorkspacePopMenu(newWs, pm);
            wkpm.Display = 1;
            // Now, add some Standard Toolbars from the *AutoCAD Default*  or *AutoCAD Classic* Workspace
            // First, get the AutoCAD Default workspace...
            Workspace defaultWS = cs.getWorkspace(ACADDEFAULT);
            if (defaultWS == null)
                // If it is not found, get the AutoCAD Classic workspace...
                defaultWS = cs.getWorkspace(ACADCLASSIC);
                    throw new ApplicationException("Default AutoCAD Workspaces not found!");
            // Add the standard "Help" Menu
            WorkspacePopMenu stMenu = defaultWS.WorkspacePopMenus.FindWorkspacePopMenu("ID_MnHelp", cs.MenuGroup.Name);
            if (stMenu != null)
                WorkspacePopMenu stNewMenu = new WorkspacePopMenu(newWs, stMenu);
                //newWs.WorkspacePopMenus.Insert(0, stNewMenu);
                stNewMenu.Display = 1;
            // Add the standard "Window" Menu
            stMenu = defaultWS.WorkspacePopMenus.FindWorkspacePopMenu("ID_MnWindow", cs.MenuGroup.Name);
            if (stMenu != null)
            // Add the standard "File" Menu
            stMenu = defaultWS.WorkspacePopMenus.FindWorkspacePopMenu("ID_MnFile", cs.MenuGroup.Name);
            if (stMenu != null)
        // **************** Add a Custom Toolbar to the workspace*******************
        void addMyToolbar(Workspace newWs)
            // Create a custom toolbar with the Polyline command and the Draw Flyout - along with the Layer dropdown control.
            // Create the toolbar
            Toolbar newTb = new Toolbar("my New Toolbar", cs.MenuGroup);
            // Add the Polyline command
            // Add the 'Draw' Flyout.
            // Now add the Layer control.
            ToolbarControl tbCtrl = new ToolbarControl(ControlType.LayerControl, newTb, -1);
            // Add the toolbar to the workspace
            WorkspaceToolbar wkTb = new WorkspaceToolbar(newWs, newTb);
            newWs.WorkspaceToolbars.Add(wkTb);
            wkTb.Display = 1;
            // Now, add some *Standard Toolbars* from the AutoCAD Default Workspace
            // Get the Standard toolbar and add it here - so we have some stock commands available.
            WorkspaceToolbar stWtb = defaultWS.WorkspaceToolbars.FindWorkspaceToolbar("ID_TbStandar", cs.MenuGroup.Name);
            if (stWtb != null)
                WorkspaceToolbar stNewWtb = new WorkspaceToolbar(newWs, stWtb);
                //newWs.WorkspaceToolbars.Insert(0, stWtb);
                stNewWtb.Display = 1;
            // Add the Workspaces toolbar, so we can switch back quickly...
            stWtb = defaultWS.WorkspaceToolbars.FindWorkspaceToolbar("ID_TbWorkspaces", cs.MenuGroup.Name);
            if (stWtb != null)
            pmi = new PopMenuItem(pm, -1); // Separator
            pmi.MacroID = "ID_Box";
            pmi.Name = "Box";
            pmi.MacroID = "ID_Pyramid";
            pmi.Name = "Pyramid";
        // Here is an example of how we can remove all of our UI elements.  This code can be run from out-of-process during uninstallation
        // of the product, though is not demonstrated here.  We still recommend that you load the CUI elements from first-run AutoCAD.
        [CommandMethod("REMOVEALL")]
        public void RemoveAllComponents()
            Workspace newWs;
            if (-1 == cs.Workspaces.IndexOfWorkspaceName(WORKSPACENAME)) // If the workspace doesnot exist
                return;
            else
            // Remove the Menus collection...
            while (newWs.WorkspacePopMenus.Count > 0)
                newWs.WorkspacePopMenus.RemoveAt(0);
            // Clear out the Custom Menu group...
            if (cs.MenuGroup.PopMenus.IsNameFree("Custom Menu") == false)
                PopMenu pop = cs.MenuGroup.PopMenus.FindPopWithName("Custom Menu");
                cs.MenuGroup.PopMenus.Remove(pop);
            // Next, make sure the workspace toolbars collection is empty
            while (newWs.WorkspaceToolbars.Count > 0)
                newWs.WorkspaceToolbars.RemoveAt(0);
            if (cs.MenuGroup.Toolbars.IsNameFree("New Toolbar") == false)
                Toolbar tb = cs.MenuGroup.Toolbars.FindToolbarWithName("New Toolbar");
                cs.MenuGroup.Toolbars.Remove(tb);
            if (cs.Workspaces.IndexOfWorkspaceName(WORKSPACENAME) > 0) // If the workspace does not exist
                cs.Workspaces.Remove(cs.Workspaces.IndexOfWorkspaceName(WORKSPACENAME));
            Application.SetSystemVariable("WSCURRENT", ACADCLASSIC);
        [CommandMethod("UPDATECUI")]
            if (cs.IsModified)
                cs.Save();
            // To do this we P/Invoke into acedCmd() in order to synchronously call the CUIUNLOAD / CUILOAD command, disarming and
            // rearming the file dialog during the process.
            ResultBuffer rb = new ResultBuffer();
            // RTSTR = 5005
            rb.Add(new TypedValue(5005, "FILEDIA"));
            rb.Add(new TypedValue(5005, "0"));
            // start the insert command
            acedCmd(rb.UnmanagedObject);
            //CUIUNLOAD
            rb.Add(new TypedValue(5005, "_CUIUNLOAD"));
            rb.Add(new TypedValue(5005, cuiMenuGroup));
            //CUILOAD
            string cuiFileName = cs.CUIFileName;
            rb.Add(new TypedValue(5005, "_CUILOAD"));
            rb.Add(new TypedValue(5005, cuiFileName));
            //int numPartialFiles;
            ////int i = 0;
                    //Application.DocumentManager.MdiActiveDocument.SendStringToExecute("cuiload " + fileNameWithQuotes + "\n", false, false, true);
                    rb.Add(new TypedValue(5005, fileNameWithQuotes));
            //FILEDIA back on
            rb.Add(new TypedValue(5005, "1"));
Hello and thank you very much.
I'll take a look at the days in peace.
After the first skim there seems to be something for me.
