.NET
Window tagging
10 REPLIES 10
Message 1 of 11
marcin.sachs
707 Views, 10 Replies
Window tagging
Hello
It is possible to tag window/ door in C#? I can import tag style from another drawing but how to attach to the window / door?
10 REPLIES 10
Message 2 of 11
Keith.Brown
in reply to: marcin.sachs
If you have your tag and it is already present in the drawing then it is simple to attach it to an object.
public bool Attach(Database db, MultiViewBlockReference tag, ObjectId doorId)
	AnchorExtendedTagToEntity tagAnchor = new AnchorExtendedTagToEntity();
	tagAnchor.SubSetDatabaseDefaults(db);
	tagAnchor.SetToStandard(db);
	tagAnchor.ForceHorizontal = false;
	tagAnchor.ReferencedEntityId = doorId;
	tag.SetAnchor(tagAnchor);
Message 3 of 11
marcin.sachs
in reply to: Keith.Brown
I get the error: "not all code paths return a value"
Message 4 of 11
Keith.Brown
Sorry I forgot to wrap in try catch and return either true or false. Or you can change return type to void.
Message 5 of 11
marcin.sachs
hmm I'm doing something wrong...
this is my all code:
public class OpeningTagAndSchedule
        public static void Create()
            var acDoc = Application.DocumentManager.MdiActiveDocument;
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var acCurDb = acDoc.Database;
            var attachedObjects = new ObjectIdCollection();
            using (var acTrans = acCurDb.TransactionManager.StartTransaction())
                var bt = (BlockTable)acTrans.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForWrite);
                var btr = (BlockTableRecord)acTrans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                try
                    TypedValue[] filterlist = new TypedValue[1];
                    //select doors and windows
                    filterlist[0] = new TypedValue(8, "A-Window-G");
                    //Get objects
                    // Request for objects to be selected in the drawing area
                    SelectionFilter filter = new SelectionFilter(filterlist);
                    PromptSelectionResult acSSPrompt = ed.GetSelection(filter);
                    ObjectId[] ids = new ObjectId[0];
                    SelectionSet selectedobjects = SelectionSet.FromObjectIds(ids);
                    if (acSSPrompt.Status == Autodesk.AutoCAD.EditorInput.PromptStatus.OK)
                        selectedobjects = acSSPrompt.Value;
                    // Get point
                    PromptPointOptions usrPointOpts = new PromptPointOptions("Enter insertion point: ");    //prompt for point
                    PromptPointResult usrPointRes = ed.GetPoint(usrPointOpts);                                //get user point
                    Point3d leftCornerPoint = usrPointRes.Value;                                                               //store user value
                    Database dbDestination = HostApplicationServices.WorkingDatabase;
                    string SourcePath = @"C:\\Program Files\\Autodesk\\ApplicationPlugins\\CAD+\\resources\\Tags & Schedules.dwg";
                    Database dbSource = new Database(false, true);
                    dbSource.ReadDwgFile(SourcePath, System.IO.FileShare.Read, true, "");
                    ////  get the Tags Style
                    DictionaryMultiViewBlockDefinition TagStyle = new DictionaryMultiViewBlockDefinition(dbSource);
                    ObjectIdCollection objCollectionsrc=new ObjectIdCollection();
                    objCollectionSrc.Add(TagStyle.GetAt("MiTek_Window_Tag"));
                    objCollectionSrc.Add(TagStyle.GetAt("MiTek_Door_Tag"));
                    CloningHelper helpme = new CloningHelper();
                    helpme.MergeType = DictionaryRecordMergeBehavior.Normal;
                    helpme.Clone(dbSource, dbDestination, objCollectionSrc, TagStyle.RecordType, true);
                    objCollectionSrc.Clear();
                    //  get the Schedules Style
                    DictionaryScheduleTableStyle ScheduleStyle = new DictionaryScheduleTableStyle(dbSource);
                    //ObjectIdCollection objCollectionsrc=new ObjectIdCollection();
                    objCollectionSrc.Add(ScheduleStyle.GetAt("MiTek Door Schedule"));
                    objCollectionSrc.Add(ScheduleStyle.GetAt("MiTek Window Schedule"));
                    CloningHelper helpme2 = new CloningHelper();
                    helpme2.MergeType = DictionaryRecordMergeBehavior.Normal;
                    helpme2.Clone(dbSource, dbDestination, objCollectionSrc, ScheduleStyle.RecordType, true);
                    var tag = new MultiViewBlockReference();
                    tag.SetDatabaseDefaults(acCurDb);
                    tag.SetToStandard(acCurDb);
                    var mvBlks = new DictionaryMultiViewBlockDefinition(acCurDb);
                    var mvBlkDefId = mvBlks.GetAt("MiTek_Window_Tag");
                    tag.StyleId = mvBlkDefId;
                    tag.Scale = new Scale3d(1);
                    btr.AppendEntity(tag);
                    acTrans.AddNewlyCreatedDBObject(tag, true);
                    //MultiViewBlockReference tag = "MiTek_Window_Tag"
                    foreach (Autodesk.AutoCAD.DatabaseServices.ObjectId obj in selectedobjects)
                        //Attach(acCurDb, tag, obj);
                    Vector3d vector1 = new Vector3d(3500, 0, 0);
                    Point3d leftCornerPoint2 = new Point3d();
                    leftCornerPoint2 = leftCornerPoint.Add(vector1);
                    ed.Command("-SCHEDULEADD", "MiTek Door Schedule", "A-Door-G", "_N", "_N", "_Y", "_Y", selectedobjects, "", leftCornerPoint, "");
                    ed.Command("-SCHEDULEADD", "MiTek Window Schedule", "A-Window-G", "_N", "_N", "_Y", "_Y", selectedobjects, "", leftCornerPoint2, "");
                catch (System.Exception e)
                    ed.WriteMessage(e.Message);
                acTrans.Commit();
        public static  void Attach(Database db, MultiViewBlockReference tag, ObjectId objId)
            tagAnchor.ReferencedEntityId = objId;
Message 6 of 11
Keith.Brown
What line is causing the error in visual studio?
I also noticed that you created a new mvblock reference and added it to the database but I do not see where you are setting its location.  It might default to 0,0,0 but i am not sure.
Message 7 of 11
marcin.sachs
error is obtained in AutoCAD not in Visual Studio
only if I use:
Message 8 of 11
Keith.Brown
Sorry i didnt catch that error.  A SelectionSet is a container for a SelectedObject not an ObjectId.
You need to do this instead.
foreach (SelectedObject obj in selectedObjects)
     // do something with the obj.ObjectId
Message 9 of 11
marcin.sachs
Right. Now is working 🙂 but tag is insering always in start point of opening.
Message 10 of 11
marcin.sachs
Sorry for my previous post I'm writing this quickly on my phone.
I create LineSegment2d from start point to end point of opening. I'm getting mid point of linesegment2d I'm trying insert tag in this point but it is inserted always in start point of opening.
                try
                    filterlist[0] = new TypedValue(8, "A-Door-G,A-Window-G");
                    //Get objects
                    // Get point
                    MiiInsulation.Common.GetLayer(acTrans, acCurDb, "A-Door-T", (short)21, false);
                    MiiInsulation.Common.GetLayer(acTrans, acCurDb, "A-Window-T", (short)91, false);
                    foreach (SelectedObject obj in selectedobjects)
                        Autodesk.Aec.DatabaseServices.DictionaryMultiViewBlockDefinition mvbstyledict;
                        ObjectId bstyleID = obj.ObjectId;
                        var geo = bstyleID.GetObject(OpenMode.ForRead, false) as Geo;
                        Autodesk.Aec.DatabaseServices.MultiViewBlockReference tag;
                        tag = new Autodesk.Aec.DatabaseServices.MultiViewBlockReference();
                        Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = acCurDb.TransactionManager;
                        mvbstyledict = new Autodesk.Aec.DatabaseServices.DictionaryMultiViewBlockDefinition(acCurDb);
                        LineSegment2d line = new LineSegment2d(new Point2d(geo.StartPoint.X , geo.StartPoint.Y),
                            new Point2d(geo.StartPoint.X, geo.StartPoint.Y).GetVectorTo(new Point2d(geo.EndPoint.X, geo.EndPoint.Y)));
                        Point3d midpoint = new Point3d(line.MidPoint.X, line.MidPoint.Y, 0.0);
                        string layer = "";
                        Autodesk.AutoCAD.DatabaseServices.DBObject objk = acTrans.GetObject(bstyleID, OpenMode.ForRead);
                        Autodesk.Aec.Arch.DatabaseServices.Door door = objk as Autodesk.Aec.Arch.DatabaseServices.Door;
                        Autodesk.Aec.Arch.DatabaseServices.Window window = objk as Autodesk.Aec.Arch.DatabaseServices.Window;
                        if (door != null)
                            bstyleID = mvbstyledict.GetAt("MiTek_Door_Tag");
                            layer = "A-Door-T";
                            ed.WriteMessage("\nDoor");
                        if (window != null)
                            bstyleID = mvbstyledict.GetAt("MiTek_Window_Tag");
                            layer = "A-Window-T";
                            ed.WriteMessage("\nWindow");
                        objk.Dispose();
                        tag.BlockDefId = bstyleID;
                        tag.Layer = layer;
                        tag.Scale = new Scale3d(100);
                        //tag.Direction = geo.Direction;
                        tag.Location = midpoint;
                        Attach(acCurDb, tag, obj.ObjectId);
                acTrans.Commit();
            tag.Location = new Point3d(0,0,0);
Message 11 of 11
marcin.sachs
It's working!
full working code below:
        public static void OpeningTagging()
                try
                    //Get objects
                    // Get point
                    dbSource.CloseInput(true);
                    CAD_.Functions.BasicFunctions.CreateLayer("A-Window-T", Color.FromColorIndex(ColorMethod.ByAci, 91), "Fine");
                    CAD_.Functions.BasicFunctions.CreateLayer("A-Door-T", Color.FromColorIndex(ColorMethod.ByAci, 21), "Fine");
                        string layer = "";
                        if (door != null)
                            layer = "A-Door-T";
                        if (window != null)
                        objk.Dispose();
                        double length = geo.StartPoint.DistanceTo(geo.EndPoint) / 2;
                        tag.Layer = layer;
                        tag.Location = new Point3d(tag.Location.X + length, tag.Location.Y + 400, tag.Location.Z);
                        tag.Rotation = 0;
                        Attach(acCurDb, tag, obj.ObjectId, midpoint);
                acTrans.Commit();
        public static  void Attach(Database db, MultiViewBlockReference tag, ObjectId objId, Point3d midpoint)
            tagAnchor.ForceHorizontal = true;
”Boost
