while entity jigging to show dynamic dimension
insmuratturna
insmuratturna
I have my own block.jig(entity)  and I want to show ( dynamic dimension)distance of between two block to user while jigging.
If it is possible how can to do.
I tried something to get it (inspired by the link below) .I used two jigs intertwined but I can't see block and distance at the same time as you can see attached file
https://spiderinnet1.typepad.com/blog/2012/03/autocad-net-entityjig-jig-line-by-start-and-end-points...
Norman_Yuan
I have some code as prove of concept for your question here:
https://drive-cad-with-code.blogspot.com/2020/04/jig-with-dimension.html
HTH
Norman Yuan
Drive CAD With Code
