I know I'm beating a dead horse as there are a couple of other posts that explain this. However I'm not getting the expected result the other posts are getting. I am trying to print to a PDF using the "DWG To PDF.pc3". It prints with the exception that the orientation is off(see pic below).I've tried media: "ANSI_full_bleed_A_(11.00_x_8.50_Inches)" and "ANSI_full_bleed_A_(8.50_x_11.00_Inches)". There was no difference. I've tried the plotsettings.SetPlotRotating(PlotSetting, PlotRotation.Degrees090); which didn't make a difference either. If I manually print and set the orientation to horizontal; I get the right print. What am I missing?
