using .net reactor product to protect code
JamesMaeding
Advisor Advisor
JamesMaeding
I want to use .net reactor to protect code:
http://www.eziriz.com/dotnet_reactor.htm
Its super easy to use, you just add your files to a list, and hit protect.
Only problem is the acad dll's referenced are not found, as those are never "copy local" and it will not protect the dlls.
I emailed their support, but no response yet, and they Germany based.
Anyone tried that product and got it to work?
I could try setting copy local to true, but an not sure if that will cause problems later.
If we can get it to work, I think many other people should be using it as dll's are too easy to decompile so we get less commercial products created or shared for free.
thanks
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Keith.Brown
My company uses .NET Reactor and I have done it two ways.  My boss likes to set copy local = true and just set the working directory to the AutoCAD Directory.
I like to set copy local = false and on a successful build i copy my dll to a folder where I will use .NET Reactor.  In that folder i manually copied the files that .NET reactor needs in order to run.  Everything works fine after that.
help me how , i can generate one license using a server linux and mono with .Net Reactor?
