Use CefSharp in wpf plugin
luc.vallotP8MJ4
luc.vallotP8MJ4
I need to use a CefSharp webbrowser (last version) in my plugin
the broswer must be integrated in a wpf modal dialog (not in a palette)
Then I try this , or then I try to use some Cef componant by code (instancing a CefSetting object for exemple), the plugin crash, saying it is impossible to load some dependancies of the cef dll.
If I try Netload of the Cef Dll's manualy, the same error occurs
I know Autocad use a special integrated version of CefSharp , and persaps, it is the cause of the problem.
So, how can I solve this ?
or is it possible to directly use the autodesk version of Cef in place of the standard CefSharp componant ?
Thanks in advance
Luc
luc.vallotP8MJ4
nobody can help me ?
norman.yuan
Not an answer to your question, rather it is a question to your question 🤔
In .NET Framework, WPF comes with WebBroweser control, which is wrapped ActiveX control of Internet Explorer. How do you use/set up your WPF form to use CefSharp instead of WPF built-in WebBrowser control?
Norman Yuan
Drive CAD With Code
luc.vallotP8MJ4
Hi Norman,
I use a web browser to access okta fonctionalities and I have compatibility problems with IE
So I search another (free) web browser to implement this
Luc
