Private Sub callback_commandWillStart(ByVal sender As Object, ByVal e As CommandEventArgs)
If e.GlobalCommandName = "EATTEDIT" Then
MsgBox("hey")
Return
ElseIf e.GlobalCommandName = "POWEREDITINAPP" Then
AddHandler myDB.ObjectModified, AddressOf callback_ObjectModified
AddHandler myDoc.CommandEnded, AddressOf callback_CommandEnded
End Sub
Private Sub callback_ObjectModified(ByVal sender As Object, ByVal e As ObjectEventArgs)
Dim trans As Transaction = e.DBObject.Database.TransactionManager.StartTransaction
Try
Dim obj As Object = trans.GetObject(e.DBObject.Id, OpenMode.ForRead)
If obj.GetType.Name.ToString = "BlockReference" Then
If Not IDList.Contains(e.DBObject.Id) Then
IDList.Add(e.DBObject.Id)
Debug.Print(e.DBObject.Id.ToString)
Debug.Print(sender.ToString)
MsgBox(obj.GetType.Name.ToString)
Dim myBlockRef As BlockReference = e.DBObject.Id.GetObject(OpenMode.ForRead)
Dim BTR As BlockTableRecord = myBlockRef.BlockTableRecord.GetObject(OpenMode.ForRead)
MsgBox(BTR.Name)
Catch ex As Exception
End Try
trans.Dispose()
End Sub
Private Sub callback_CommandEnded(ByVal sender As Object, ByVal e As CommandEventArgs)
If IDList.Count > 0 Then
Dim myDWG As Document = DocumentManager.MdiActiveDocument
Dim objid As ObjectId
Try
Using trans As Transaction = myDWG.TransactionManager.StartTransaction
For Each objid In IDList
Dim myent As Entity = objid.GetObject(OpenMode.ForRead)
Dim myBlockRef As DatabaseServices.BlockReference = objid.GetObject(OpenMode.ForRead)
Dim myattcoll As DatabaseServices.AttributeCollection = myBlockRef.AttributeCollection
Dim myAttent As DatabaseServices.ObjectId
Dim myAttRef As AttributeReference
For Each myAttent In myattcoll
myAttRef = myAttent.GetObject(OpenMode.ForRead)
Debug.Print(myAttRef.Tag)
Next
Debug.Print(myent.Layer)
Debug.Print(objid.ToString)
'MsgBox(e.GetType.ToString)
Next
IDList.Clear()
End Using
End Try
End Sub
Hey All
I'm trying to write a program that updates a block attribute based on the change of another attribute. The code I've got so far seams to work as far as printing to the immediate window but whenever I try to open anything for write I get an exception.
Here is the code I've got so far.
