Unable to add AcETransmit library reference
nmeek
nmeek
I have created a new AutoCAD plug-in project in Visual Studio Professional 2013 by using the template installed from the ObjectARXWizzards.msi.
When attempting to add a reference to the Transmittal Object Library, per To Reference the Transmittal Object Library, I get the following error:
A reference to 'C:\ObjectARX 2016\inc-x64\AcETransmit19.tlb' could not be added. Please make sure that the file is accessible, and that it is a valid assembly or COM component.
(References to AcCoreMgd.dll and AcDbMdg.dll were added successfully from the C:\ObjectARX 2016\inc folder)
Any help would be greatly appreciated.
nmeek
After much searching, I found the resolution on this AutoCAD DevBlog page: Resolving references when using tlbimp
By using tlbimp.exe (from the Windows SDK) I created an inter-op assembly from the AcETransmit19.tlb type library using the following:
tlbimp  "C:\ObjectARX 2016\inc-x64\AcETransmit19.tlb" /out:AcETransmit19.Interop.dll /namespace:AcETransmit /machine:x64
I was then able to add a reference to the assembly to my plug-in project.
