.NET
Trying to mimic LAYUNISO command
10 REPLIES 10
Message 1 of 11
nam_h_tran
330 Views, 10 Replies
The code below im trying to mimic the ability of layuniso command. But it not make the layer faded restored back to normal. Although it restore everything normally like layuniso. Im trying to regen model too but seem like it not working.
here below the code:
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using TrainingAutoCAD.Helpers;
var doc = Application.DocumentManager.MdiActiveDocument;
var ed = Application.DocumentManager.CurrentDocument.Editor;
var db = Application.DocumentManager.CurrentDocument.Database;
using (var tr = db.TransactionManager.StartTransaction())
LayerStateManager acLyrStMan;
acLyrStMan = doc.Database.LayerStateManager;
DBDictionary? acDbDict;
acDbDict = tr.GetObject(acLyrStMan.LayerStatesDictionaryId(true),
OpenMode.ForWrite) as DBDictionary;
string sLyrStName = "_LAYISO_STATE";
if (acLyrStMan.HasLayerState(sLyrStName) == true)
var rb = acDbDict.XData;
if (rb != null)
int index = 0;
foreach (TypedValue typeVal in rb)
if (index == 1)
string layoutValue = $"*{typeVal.Value.ToString()}";
Application.SetSystemVariable("CLAYOUT", layoutValue);
break;
index++;
acLyrStMan.RestoreLayerState(sLyrStName,
ObjectId.Null,
0,
LayerStateMasks.On |
LayerStateMasks.Locked |
LayerStateMasks.Frozen |
LayerStateMasks.CurrentViewport |
LayerStateMasks.NewViewport);
acLyrStMan.DeleteLayerState(sLyrStName);
acDbDict.Erase();
ed.Regen();
tr.Commit();
ed.Regen();
10 REPLIES 10
Message 2 of 11
diendev16
in reply to: nam_h_tran
KHó quá bỏ qua đi anh ơi
Message 3 of 11
_gile
Sometimes, it is much more simple to call the native command.
if (doc.Database.LayerStateManager.HasLayerState("_LAYISO_STATE"))
    doc.Editor.Command("_LAYUNISO");
Gilles Chanteau
GileCAD
GitHub
Message 4 of 11
nam_h_tran
in reply to: _gile
a, im trying to mimic the layuniso command. But don't find any type of regen or redraw the drawing area like layuniso. When im using editor.regen it will always going with regenerating model... message
Message 5 of 11
18348401357
yes  the layer faded can't back  is a is a typical problem ,try to use LayerUtilities.RegenLayers Method, In advanced version it's CoreLayerUtilities.RegenLayers, the RegenPending is a property of LayerUtilities
Message 6 of 11
nam_h_tran
in reply to: 18348401357
Thanks, base on you i found this topic:
Topic about layer unlock, faded,hide ( chinese language)
And here is my code for that:
Regen Layers :
           var lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
           ObjectId[] layerIds = lt.Cast<ObjectId>().ToArray();
           RegenLayers(layerIds);
        public static void RegenLayers(ObjectId[] layerIds)
            dynamic acad = Application.AcadApplication;
            int majorVersion = int.Parse(acad.Version.Split('.')[0]);
            var type = majorVersion >= 21
                ? Assembly.Load("accoremgd")?.GetType("Autodesk.AutoCAD.Internal.CoreLayerUtilities")
                : Assembly.Load("acmgd")?.GetType("Autodesk.AutoCAD.Internal.LayerUtilities");
            var majorInfo = type?.GetMethod("RegenLayers", new[] { typeof(ObjectId[]), typeof(int) });
            var propertyInfo = type?.GetProperties().FirstOrDefault(e => e.Name == "RegenPending");
            var regenPending = (int)(propertyInfo?.GetValue(null) ?? 0);
            majorInfo?.Invoke(null, new object[] { layerIds, regenPending });
Message 7 of 11
nam_h_tran
But i don't understand i can't find any document about LayerUtilities or CoreLayerUtilities in autocad. It should be a document for this somewhere right?
Message 8 of 11
18348401357
oh I know this man, he is a member of our organization, and he quoted my post in this article.
The link that the arrow points to is mine
Message 9 of 11
nam_h_tran
Again thanks a lots. I was never think about these.
Message 10 of 11
nam_h_tran
Hi. Sorry to open this topic again. But you know how to handle it in object arx? (c++). Or how to call the internal library of autocad in object arx?. Here the full verion of code in c++: Im using ads_regen() but it same problem in C#
RestoreLayer()
	AcString          M1 = multilingual_.GetValue(L"M1");
	AcDbDatabase* db = acdbHostApplicationServices()->workingDatabase();
	AcDbLayerStateManager* layerStateManager = db->getLayerStateManager();
	try
		if (layerStateManager->hasLayerState(LAYER_NAME) == true)
			AcDbDictionary* dic_layerstate;
			Acad::ErrorStatus  es = acdbOpenObject(dic_layerstate, layerStateManager->layerStatesDictionaryId(true), kForRead);
			if (es == Acad::eOk && dic_layerstate != nullptr)
				GetLayoutAndViewPort(dic_layerstate);
			RestoreData(layerStateManager, db);
			layerStateManager->deleteLayerState(LAYER_NAME);
			ads_regen();
		else
			throw acutPrintf(multilingual_.GetValue(L"M2"));
	catch (...)
		throw;
Message 11 of 11
nam_h_tran
I found out the answer for the RegenLayer in ObjectArx (c++) too:
void __stdcall acedRegenLayers(
	class AcArray<class AcDbObjectId, class AcArrayMemCopyReallocator<class AcDbObjectId>> const&,
	int);
static Acad::ErrorStatus GetLayerObjectIdArray(AcDbObjectIdArray& objIds, bool External = true)
	Acad::ErrorStatus     es = Acad::eOk;
	AcDbLayerTablePointer pTable(acdbCurDwg()->layerTableId());
	if (pTable.openStatus() != Acad::eOk)
		return es;
	AcDbLayerTableIterator* pIter(nullptr);
	es = pTable->newIterator(pIter);
	if (es != Acad::eOk)
		return es;
	AcDbLayerTableRecord* pRecord(nullptr);
	for (pIter->start(); !pIter->done(); pIter->step())
		es = pIter->getRecord(pRecord, AcDb::kForRead);
		if (es == Acad::eOk)
			if (pRecord->isDependent() && External)
				objIds.append(pRecord->objectId());
			else
		pRecord->close();
	delete pIter;
	return es;
static void RegenLayer()
	AcDbObjectIdArray layerIds{};
	GetLayerObjectIdArray(layerIds);
	acedRegenLayers(layerIds, 0);
AutoCAD Inside the Factory
