Training on .net for acad?
This widget could not be displayed.
Are there any .net classes available geared toward autocad/inventor?
There are some through the Autodesk Developer Network. There were also some
for AutoCAD at AU, and there may have been some for Inventor, but I did not
look for those.
Regards from Los Angeles,
Emmanuel
"Bob Quinn" wrote in message
news:5805980@discussion.autodesk.com...
Daniel.Du
Have you ever been here?
http://www.autodesk.com/developautocad
http://www.autodesk.com/developinventor
Daniel Du
Developer Technical Services
JamesMaeding
Part of the problem is those classes do not talk about how to structure "libraries" of things.
This matters because you would want to reuse as much as possible, and avoid duplicate code with minor tweaks for different target versions.
So getting used to .net itself must be done in order to make the cad programming smooth.
I can explain how I organize things if needed, I am always looking for better ways myself.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
