Texts to listbox C#
Texts to listbox C#
k005
Advisor Advisor
Message 1 of 14
Texts to listbox C#
k005
How can I send text objects in the dwg file to the listbox by selecting them?
common feature in texts to be selected = ø
sample text:
51ø16 / 20
Replies (13)
Message 2 of 14
essam-salah
hi
do use wpf or winforms?
Message 3 of 14
k005
Winforms    ( .dll )
Message 4 of 14
essam-salah
hi @k005
just create .NetFramwork ClassLibrary and add System.Windows.Forms assembly to your project references,
and try this:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using aDB = Autodesk.AutoCAD.DatabaseServices;
using aApp = Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using aGeom = Autodesk.AutoCAD.Geometry;
namespace ACADAPITutorial
    public class TextToListBox
        #region current doc
        static aApp.Document aDoc => aApp.Application.DocumentManager.MdiActiveDocument;
        #endregion
        #region initialize
        private static bool isDialogOpen = false;
        private static SelectionDialog dialog;
        static TextToListBox()
            dialog = new SelectionDialog();
            dialog.SelectBtm.Click += SelectBtm_Click;
            dialog.FormClosing += Dialog_FormClosing;
        static void Dialog_FormClosing(object sender, System.Windows.Forms.FormClosingEventArgs e)
            e.Cancel = true;
            dialog.Hide();
        #endregion
        // select text
        private static void SelectBtm_Click(object sender, EventArgs e)
            // define filter
            // TypedValue /filter criteria
            var typeValueArray = new aDB.TypedValue[]
                    new aDB.TypedValue((int)aDB.DxfCode.Operator, "<or"), // start ORing
                    new aDB.TypedValue((int)aDB.DxfCode.Start, "Text"),
                    new aDB.TypedValue((int)aDB.DxfCode.Start, "MText"),
                    new aDB.TypedValue((int)aDB.DxfCode.Operator, "or>"), // end ORing
                    // to get any ACAD Obj dxf name (Text, MText , ...) use ACAD LIST command.
            var filter = new SelectionFilter(typeValueArray);
            // selection options
            var selectionOptions = new PromptSelectionOptions()
                MessageForAdding = "select texts",
            // Request for objects to be selected in the drawing area
            var selectionResult = aDoc.Editor.GetSelection(selectionOptions, filter);
            // If the prompt status is OK, objects were selected
            if (selectionResult.Status != PromptStatus.OK)
                aDoc.Editor.WriteMessage($"\n----- No selection found ------");
                return;
            // get object IDs
            var allTextIDs = selectionResult.Value.GetObjectIds();
            List<string> allText = new List<string>();
            using (var ts = aDB.HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
                Type type;
                foreach (var id in allTextIDs)
                    var dbObj = id.GetObject(aDB.OpenMode.ForRead);
                    type = dbObj.GetType();
                    if (type.Equals(typeof(aDB.DBText)))
                        allText.Add(((aDB.DBText)dbObj).TextString);
                    else if (type.Equals(typeof(aDB.MText)))
                        allText.Add(((aDB.MText)dbObj).Text);
            dialog.ListBox.DataSource = allText;
        [CommandMethod("cieSelectText")]
        public void SelectText()
            // check already opened
            if (isDialogOpen) return;
            // show modeless dialog
            aApp.Application.ShowModelessDialog(dialog);
            isDialogOpen = true;
and here is a simple form:
public class SelectionDialog : System.Windows.Forms.Form
        public System.Windows.Forms.ListBox ListBox { get; private set; }
        public System.Windows.Forms.Button SelectBtm { get; private set; }
        public SelectionDialog()
            SelectBtm = new System.Windows.Forms.Button()
                Text = "select...",
            ListBox = new System.Windows.Forms.ListBox()
            // wrap all controls into a panel
            var panel = new System.Windows.Forms.FlowLayoutPanel()
                AutoScroll = true,
                FlowDirection = System.Windows.Forms.FlowDirection.TopDown,
                WrapContents = false,
            panel.Controls.Add(SelectBtm);
            panel.Controls.Add(ListBox);
            // add controls to dialog
            this.Controls.Add(panel);
Message 5 of 14
k005
I received the articles with the code you selected (text object) and sent to the listbox. I took one more step thanks to you. If I can complete it, it will be a good work.
Thank you so much..
Message 6 of 14
k005
I could not integrate the codes you sent to the project I was working on. I'm new to C #. I prepared a screen video to detail the subject.
https://www.dosya.tc/server33/j393xz/AcadPlugin.rar.html
The choice will be based on the Layer and Text text. Mtext is not included in the selection.
Some texts (text objects) are composed of 2 texts, while some texts are 3 parts. I do not know how we can edit this. It takes a very long time.
For now, just: If we can take 3 pieces or 2 pieces of text like 1 51ø16 / 200 L = 10500 and put it into the listbox, it is enough for now.
Thank you very much for your help and Codes.
Message 7 of 14
essam-salah
hi @k005
couldn't open the .zip file you attached i think it's better if you make it a GIF so we can see it or a link to YouTube video,
if you want to select Text in a specific layer just change the above code typeValueArray to:
 var myLayerName = "myLayer";
                    new aDB.TypedValue((int)aDB.DxfCode.Operator, "<and"),
                    new aDB.TypedValue((int)aDB.DxfCode.LayerName, myLayerName),
                    new aDB.TypedValue((int)aDB.DxfCode.Operator, "and>"),
and the question about a Text with text parts isn't clear actually,
Message 8 of 14
k005
our road map has been determined. We must proceed from this part...
SelectBtm_Click
Message 9 of 14
essam-salah
Message 10 of 14
k005
Message 11 of 14
mttlp
Merhaba videoları nı sesli çekeydin iyi olurdu donatı metraj programına yardımcı olurum.
Message 12 of 14
essam-salah
hi @k005 , i got your video
man it's a big task i don't think someone here will give you a complete project,
what i understand is you have some texts in your drawing and each 3(or 2) texts are related to each other which gives information about a rebar and your task is to collect these related texts together .
since you are not expert i suggest to look for someone in the industry.
Message 13 of 14
k005
Sesli de hazırlarım. Ancak ücretli ile tam istediğim sonucu alamayabiliriz.
Öğrenmem gerekiyor.
Teşekkürler.
Message 14 of 14
k005
@essam-salah
Yes . the subject is exactly as you said. I am not an expert. but I understood the code structure. I need to get a listbox with Text objects filtered. I have included some of the code you sent in my Project.
Now the filtering is left.
Thank you so much.
