SQL Server Name property of a project
thorgul
thorgul
On plant3d I have project that are on different SQL Server and I wanted to know if it is possible to access this property
so that depending of the project I am always on the right server
thanks
jabowabo
Autodesk.ProcessPower.DataLinks.DataLinksManager.GetPnPDatabase().DBEngine.DbName
jabowabo
If you don't want to use the API, you can also get it from any of the project .dcf files.
thorgul
thanks for the reply but this give me the path of the .dcf files. We are using Vault with plant3d is that the reason ?
jabowabo
If the .dcf path is returned, that means it's a SQLite project - not hosted on SQL server.
thorgul
That's because we are using Autodesk Vault to hold our projects the sqllite is just from the working folder.
