I'm new to this stuff, but after spending hours researching and troubleshooting I am still banging my head against the wall trying to get some pretty simple Sheet Set Manager API code to run correctly. Here are some of details of my setup:
- AutoCAD 2024 Full License
- Visual Studio 2022
- Windows 10
These are steps I took:
Project Setup
- Create a new Class Library (.NET Framework) project in Visual Studio
- Target .NET Framework 4.8 (compatible with AutoCAD 2024, Yes, I know this changes for 2025)
- VS -> Build -> Configuration Manager -> Platform x64
Add references from the following:
- References:
1. AcSmComponents24.tlb From -> C:\Program Files\Common Files\Autodesk Shared
2. acmgd.dll From -> C:\Program Files\Autodesk\AutoCAD 2024
3. acdbmgd.dll From -> C:\Program Files\Autodesk\AutoCAD 2024
4. accoremgd.dll From -> C:\Program Files\Autodesk\AutoCAD 2024
- I made the repos location a trusted location in AutoCAD
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
// Register the assembly
[assembly: ExtensionApplication(typeof(SheetSetManagerExample.SheetSetManagerPlugin))]
[assembly: CommandClass(typeof(SheetSetManagerExample.SheetSetManagerCommands))]
namespace SheetSetManagerExample
// Main plugin class
public class SheetSetManagerPlugin : IExtensionApplication
public void Initialize()
// Initialization code when AutoCAD loads the plugin
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nSheet Set Manager plugin loaded.\n");
public void Terminate()
// Cleanup when AutoCAD unloads the plugin
// Class containing AutoCAD commands
public class SheetSetManagerCommands
// Define AutoCAD commands using the CommandMethod attribute
[CommandMethod("SSMOpenSheetSet")]
public void OpenSheetSet()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
try
// Get DST file path from user
PromptOpenFileOptions opt = new PromptOpenFileOptions("Select a Sheet Set (DST file)")
Filter = "Sheet Set Files (*.dst)|*.dst"
PromptFileNameResult res = ed.GetFileNameForOpen(opt);
if (res.Status != PromptStatus.OK) return;
string dstFilePath = res.StringResult;
// Create a SheetSetManager helper to work with the Sheet Set
using (SheetSetManager ssm = new SheetSetManager())
ssm.OpenSheetSet(dstFilePath);
ssm.DisplaySheetSetInfo();
catch (System.Exception ex)
ed.WriteMessage("\nError: " + ex.Message);
[CommandMethod("SSMCreateSheetSet")]
public void CreateSheetSet()
try
// Get DST file path from user for the new sheet set
PromptSaveFileOptions opt = new PromptSaveFileOptions("Specify location for new Sheet Set (DST file)")
PromptFileNameResult res = ed.GetFileNameForSave(opt);
ssm.CreateSheetSet(dstFilePath, "New Sheet Set", "New sheet set created via API");
[CommandMethod("SSMAddSheet")]
public void AddSheet()
try
PromptOpenFileOptions dstOpt = new PromptOpenFileOptions("Select a Sheet Set (DST file)")
PromptFileNameResult dstRes = ed.GetFileNameForOpen(dstOpt);
if (dstRes.Status != PromptStatus.OK) return;
string dstFilePath = dstRes.StringResult;
// Get DWG file path from user
PromptOpenFileOptions dwgOpt = new PromptOpenFileOptions("Select a Drawing (DWG file)")
Filter = "Drawing Files (*.dwg)|*.dwg"
PromptFileNameResult dwgRes = ed.GetFileNameForOpen(dwgOpt);
if (dwgRes.Status != PromptStatus.OK) return;
string dwgFilePath = dwgRes.StringResult;
// Get the layout name
PromptStringOptions layoutOpt = new PromptStringOptions("\nEnter layout name: ")
AllowSpaces = true,
DefaultValue = "Layout1"
PromptResult layoutRes = ed.GetString(layoutOpt);
if (layoutRes.Status != PromptStatus.OK) return;
string layoutName = layoutRes.StringResult;
ssm.AddSheet(dwgFilePath, layoutName, "Sheet " + DateTime.Now.ToString("yyyyMMdd"), "New sheet added via API");
[CommandMethod("SSMAddCustomProperty")]
public void AddCustomProperty()
try
// Get property name
PromptStringOptions propNameOpt = new PromptStringOptions("\nEnter property name: ")
AllowSpaces = false
PromptResult propNameRes = ed.GetString(propNameOpt);
if (propNameRes.Status != PromptStatus.OK) return;
string propName = propNameRes.StringResult;
// Get property value
PromptStringOptions propValueOpt = new PromptStringOptions("\nEnter property value: ")
AllowSpaces = true
PromptResult propValueRes = ed.GetString(propValueOpt);
if (propValueRes.Status != PromptStatus.OK) return;
string propValue = propValueRes.StringResult;
ssm.AddCustomPropertyToSheetSet(propName, propValue);
[CommandMethod("SSMCreateSubset")]
public void CreateSubset()
try
// Get subset name
PromptStringOptions nameOpt = new PromptStringOptions("\nEnter subset name: ")
AllowSpaces = true
PromptResult nameRes = ed.GetString(nameOpt);
if (nameRes.Status != PromptStatus.OK) return;
string subsetName = nameRes.StringResult;
// Get subset description
PromptStringOptions descOpt = new PromptStringOptions("\nEnter subset description: ")
AllowSpaces = true
PromptResult descRes = ed.GetString(descOpt);
if (descRes.Status != PromptStatus.OK) return;
string subsetDesc = descRes.StringResult;
ssm.CreateSubset(subsetName, subsetDesc);
No errors when I rebuild it in VS. There are these two warnings:
1. warning MSB3305: Processing COM reference "AXDBLib" from path "C:\Program Files\Common Files\Autodesk Shared\axdb24enu.tlb". Interface 'IAcadShadowDisplay' is marked as [dual], but does not derive from IDispatch. It will be converted as an IUnknown-derived interface.
2. warning MSB3305: Processing COM reference "ACSMCOMPONENTS24Lib" from path "C:\Program Files\Common Files\Autodesk Shared\AcSmComponents24.tlb". At least one of the arguments for 'IAcSmFiler.ReadRawData' cannot be marshaled by the runtime marshaler. Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
But what I found online is saying these wont be an issue.
I can load the plugin in AutoCAD and run some of the commands. It lets me select the .dst file and will return some of it's values. I see this error a bunch: "Warning checking for open database: Error HRESULT E_FAIL has been returned from a call to a COM component." and this one too: " Object reference not set to an instance of an object."
I feel like there must be something simple I'm missing but can't be sure. Any help would be appreciated.
