Setting and accessing USERS1 variable
TK_Rao5AR2
New Member
TK_Rao5AR2
New Member
New Member
Here is something interesting that I thought I knew well for decades.
I thought USERS1 is a setvar that can be set and accessed. This is true as long as I am in the same  API context, meaning if I am using COM (ActiveX) then this is set and returned in a document context. If I am using .Net then it can only be set using Application.SetSystemVariable and accessed using Application.GetSystemVariable.
My situation is that I want to set this in .Net using Application.SetSystemVariable and access it from COM that is out of process. I am unable to get the desired value here. Can someone shed more light on these USERS1 variables and the context it is created?
Note: I know USERS1 is not saved anywhere and is temporary.
-Thilak Rao
norman.yuan
-Thilak Rao
You did not describe how you are "...unable to get desired value...". However, the knowledge you knew well for decades still remains true: there is only one value of each USERSx variable, regardless how its value being set (manually at command line, with code of different APIs of LISP/COM/.NET), or where it is accessed to (from in-process, or out-process).
 I took a bit of time to write some simply code and recorded the code execution in video clip to prove it here.
This is a console app that uses AutoCAD COM API to get AutoCAD's USERS1 value:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace AcadComAutomationApp
    class Program
        static void Main(string[] args)
            Console.WriteLine("Do you want to start an AutoCAD session? (Y/N):");
            var an = Console.ReadLine();
            if (!an.ToUpper().StartsWith("Y")) return;
            var comAcad = new Autodesk.AutoCAD.Interop.AcadApplication();
            comAcad.Visible = true;
            while(true)
                if (comAcad.ActiveDocument!=null)
                    var users1 = comAcad.ActiveDocument.GetVariable("USERS1").ToString();
                    Console.WriteLine($"System variable \"USERS1\" -> {users1}");
                    Console.WriteLine("Press any key to get value again, \"X\" to quit:");
                    if (an.ToUpper().StartsWith("X"))
                        break;
                else
                    Console.WriteLine("\nNo drawing is opened in AutoCAD.");
                    Console.WriteLine("Preaa any key toopen a new/existing drawing in AutoCAD");
                    Console.WriteLine("Or press \"X\" to quit:");
                        break;
Here is a simple .NET plugin's CommandMethod that set USERS1:
        [CommandMethod("SetUserS1")]
        public static void SetUserS1Variable()
            var dwg = CadApp.DocumentManager.MdiActiveDocument;
            var ed = dwg.Editor;
            var res = ed.GetString("\nEnter value for \"USERS1\":");
            if (res.Status == PromptStatus.OK)
                CadApp.SetSystemVariable("USERS1", res.StringResult);
Here is how to run the code to prove USERS1 value is the same when accessed from the out-process (the console app) regardless how it is set:
1. Start the console app, which would start a new AutoCAD session;
2. In AutoCAD command line. enter "USERS1" to set its value manually;
3. Go back to the console app, press any key to read "USERS1" value from AutoCAD;
4. Go back to AutoCAD, load the .NET plugin and run command "SetUserS1" to set a new value to "USERS1";
5. Go back to the console app, press any key to read "USERS1" value again.
You can see that regardless how the value is set - manually, or by .NET API, the out-process app always get the latest USERS1 value, as expected. If your code does not get the "desired value", it is something wrong with your code, for sure.
To further prove what I described, see the video clip here:
2025-03-12_SetUserSX.mp4
Video Player is loading.
Current Time 0:00
Duration 2:18
Loaded: 7.24%
Stream Type LIVE
Remaining Time 2:18
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • default, selected
    (view in My Videos)
    Norman Yuan
    Drive CAD With Code
    ActivistInvestor
    I'm assuming that you are aware that USERSx system variables have document scope, and therefore have a different value for each document. So, the value assigned or returned is always the value associated with the active document.
    Type a product name
    ______
    icon-svg-close-thick
    Cookie preferences
    THIRD PARTY SERVICES
    icon-svg-hide-thick
    icon-svg-show-thick
    Qualtrics
    Akamai mPulse
    Digital River
    Dynatrace
    Khoros
    Launch Darkly
    New Relic
    Salesforce Live Agent
    Wistia
    Tealium
    Upsellit
    CJ Affiliates
    Commission Factory
    Typepad Stats
    Geo Targetly
    SpeedCurve
    Qualified
    icon-svg-hide-thick
    icon-svg-show-thick
    Google Optimize
    ClickTale
    OneSignal
    Optimizely
    Amplitude
    Snowplow
    UserVoice
    Clearbit
    YouTube
    icon-svg-hide-thick
    icon-svg-show-thick
    Adobe Analytics
    AdWords
    Marketo
    Doubleclick
    HubSpot
    Twitter
    Facebook
    LinkedIn
    Yahoo! Japan
    Naver
    Quantcast
    Call Tracking
    Wunderkind
    ADC Media
    AgrantSEM
    Bidtellect
    Bing
    G2Crowd
    NMPI Display
    VK
    Adobe Target
    Trendkite
    Hotjar
    6 Sense
    Terminus
    StackAdapt
    The Trade Desk
    RollWorks
    Your experience. Your choice.
