set style sheet (plot style table) gives an error
Message 1 of 8
When I try to change the plotstyle table :
            If acDerden = True Then
                acPlSetVdr.SetCurrentStyleSheet(acPlSet, "Dunne lijnen.ctb")
            Else
                acPlSetVdr.SetCurrentStyleSheet(acPlSet, "HP DesignJet 500.ctb")
I get an error:
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eInvalidInput
   at Autodesk.AutoCAD.DatabaseServices.PlotSettingsValidator.SetCurrentStyleSheet(PlotSettings plotSet, String styleSheetName)
   at autocad_app.vbTekening.Qplot()
But when I change the plot style table manualy (with plot, assign plotstyle to layout) then the error does not exist any
more.
Replies (7)
Message 2 of 8
The same problem by me. Anyone has a solution? Please.
Message 3 of 8
fieldguy
Are you using acPlSet.CopyFrom("whatever layout you are plotting")?  According to Kean Walmsley (http://through-the-interface.typepad.com/through_the_interface/plotting/),  "We need a PlotSettings object based on the layout settings which we then customize".
If your ctb file names are correct and the files exist in the location specified in the acad environment (Plot Style Table Search Path) then it should work.  You can also try the plot settings in the Autocad dialog and "Apply to Layout".  Then try your code again.
Message 4 of 8
I found the solution by myself.
Before you change the currentstylesheet you must refresh the plotsettings
            acPlSetVdr.RefreshLists(acPlSet)  --> this works for me
            Else
Jacco
Message 5 of 8
Thank you for your answer. I've missed this method. I've used GetPlotStyleSheet instead, it works as well.
Message 6 of 8
andy62
            Else
Jacco
Jacco,
Thank you
it works also for me.
andy
Message 7 of 8
ken
Observer
Observer
Jdsmit,
Thank you so much!
My life is worth living again!
I've been struggling thru updating a routine.
Ken
Message 8 of 8
This should be picked as the accepted answer. Solved the problem for me.
