Seperating AutoCAD surfaces with two seperate entities in one object
sbouwens
sbouwens
I'm currently working on a .net project related to slicing surfaces based on several boundaries. However, i've encountered a problem with this challenge. The problem occurs when a autocad surface is sliced in the middle, and a new surface with two or more seperate bodies is created, as seen in the image below.  Slicing this outside surface then results in an eNoIntersections error. Hence, it is needed to seperate the outside surface into two seperate entities . Then only the surface that intersects with the boundary can be selected an no error should occur.
The code snippet (VB.NET) that currently performs the task of slicing the surface is attached below:
   Dim surfaceInsideBounds = DirectCast(sliceObject, Autodesk.AutoCAD.DatabaseServices.Surface)
                                        Dim sliceResults As SurfaceSliceResults = surfaceInsideBounds.SliceBySurface(SweptSurface)
                                        Dim surfaceOutsideBounds As Autodesk.AutoCAD.DatabaseServices.Surface = sliceResults.NegativeHalfSurface
                                        surfaceOutsideBounds.SetDatabaseDefaults()
                                        surfaceOutsideBounds.Layer = sliceObject.Layer
                                        surfaceOutsideBounds.Color = sliceObject.Color
                                        btr.AppendEntity(surfaceOutsideBounds)
                                        trans2.AddNewlyCreatedDBObject(surfaceOutsideBounds, True)
The surface inside the boundary and outside the boundary needs to be preserved in this process.
I'm looking for a similar method as described in Separate Solid Complexes into Separate Solids - AutoCAD DevBlog
with solid.SeparateBody(), but then for AutoCAD Surfaces. Can anyone provide some help?
With kind regards,
Stan Bouwens
sbouwens
I'm currently stuck with the idea of exploding the surface with seperate bodies, and then unioning the parts that intersect with each other. Somewhere between lines 20-31 it somehow goes wrong.
       For Each oid In userSelectionIds
            Dim surfaceToSplit As Autodesk.AutoCAD.DatabaseServices.Surface = TryCast(acTrans.GetObject(oid, OpenMode.ForWrite), Autodesk.AutoCAD.DatabaseServices.Surface)
            Dim surfDBOBJColl As New DBObjectCollection
            Using acDBObjColl As New DBObjectCollection()
                surfaceToSplit.Explode(acDBObjColl)
                For Each DBObject In acDBObjColl
                    If DBObject.GetType() = GetType(Autodesk.AutoCAD.DatabaseServices.Surface) Then
                        surfDBOBJColl.Add(DirectCast(DBObject, Autodesk.AutoCAD.DatabaseServices.Surface))
                    ElseIf DBObject.GetType() = GetType(Autodesk.AutoCAD.DatabaseServices.Region) Then
                        Dim surface As New Autodesk.AutoCAD.DatabaseServices.Surface()
                        surface.SetDatabaseDefaults()
                        surface = Autodesk.AutoCAD.DatabaseServices.Surface.CreateFrom(DirectCast(DBObject, Autodesk.AutoCAD.DatabaseServices.Region))
                        surfDBOBJColl.Add(surface)
                    Else
                        ed.WriteMessage(vbLf & "Exploded entity is not a Surface or a Region")
                Next
            End Using
            For Each motherSurface In surfDBOBJColl
ResetJoin:
                For Each toJoinSurface In surfDBOBJColl
                    If toJoinSurface = motherSurface Then Continue For
                    Dim intersectEntity As Entity() = motherSurface.BooleanIntersect(toJoinSurface)
                    If intersectEntity IsNot Nothing Then
                        motherSurface.BooleanUnion(toJoinSurface)
                        surfDBOBJColl.Remove(toJoinSurface)
                        GoTo ResetJoin
                Next
            Next
            For Each joinedSurface In surfDBOBJColl
                joinedSurface.Layer = surfaceToSplit.Layer
                joinedSurface.Color = surfaceToSplit.Color
                btr.AppendEntity(joinedSurface)
                acTrans.AddNewlyCreatedDBObject(joinedSurface, True)
            Next
            surfaceToSplit.Erase()
        Next
        acTrans.Commit()
Can anyone provide me some guidance on joining surfaces together that overlap?
