SendCommand with error "Unhandled Access violation Reading 0xffffffffff ......
Message 1 of 22
I have   thousands of   dwg file  , i  wan't  open it  ,then  create a  closed line  , then  get  " maptrim"  command  , then  save it . I operate one by one.
I run my  code  ,   i  get  the  error "Unhandled Access violation Reading Oxffffffff  Exception at  e9e1460bh"  when  I  get about   the  fifith  file
i use  the  AutoCAD Map 2015+ .net +  com
  using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.Gis.Map.Platform.Utils;
using AutoCAD;
AcadApplication app = Application.AcadApplication as AcadApplication; if (!System.IO.File.Exists(@"C:\template500.dwg")) { Util.PrintLn("\n template is not exsit : C:\\template500.dwg"); return "err"; } Document DOC = Application.DocumentManager.Open(@"C:\template500.dwg", false); List<string> LstFiles = new List<string>(); List<string> LstCode = GetTuFuNumber.GetTuFuNum(MapCode); for (int i = 0; i < LstCode.Count; i++) { if (System.IO.File.Exists(Path + "\\" + LstCode[i] + ".dwg")) { LstFiles.Add(Path + "\\" + LstCode[i] + ".dwg"); } } string s = ""; for (int k = 0; k < LstFiles.Count; k++) { s += LstFiles[k] + ","; } //********load the file and connected file Database destDb = DOC.Database; using (DocumentLock docLock1 = DOC.LockDocument()) { for (int i = 0; i < LstFiles.Count; i++) { Database sourceDb = new Database(false, true); sourceDb.ReadDwgFile(LstFiles[i], System.IO.FileShare.Read, false, null); var SourceObjectIds = new ObjectIdCollection(); Autodesk.AutoCAD.DatabaseServices.TransactionManager SourceTm = sourceDb.TransactionManager; using (Transaction trans = destDb.TransactionManager.StartTransaction()) { var blockTable = (BlockTable)trans.GetObject(destDb.BlockTableId, OpenMode.ForRead); using (Transaction extTrans = sourceDb.TransactionManager.StartTransaction()) { dynamic extBlockTable = (BlockTable)extTrans.GetObject(sourceDb.BlockTableId, OpenMode.ForRead); dynamic extModelSpace = (BlockTableRecord)extTrans.GetObject(extBlockTable[BlockTableRecord.ModelSpace], OpenMode.ForRead); foreach (ObjectId id in extModelSpace) { SourceObjectIds.Add(id); } } sourceDb.CloseInput(true); dynamic idmapping = new IdMapping(); // destDb.WblockCloneObjects(SourceObjectIds, destDb.BlockTableId, idmapping, DuplicateRecordCloning.Replace, false); destDb.WblockCloneObjects(SourceObjectIds, blockTable[BlockTableRecord.ModelSpace], idmapping, DuplicateRecordCloning.Replace, false); trans.Commit(); } } } CWriteLog.Msg(targetPath, "finish load file "); Util.PrintLn("create polyline......."); app.ActiveDocument.SendCommand("filedia 0 \n"); Polyline line = getLine(MapCode); //**** add the polyline to modespace using (DOC.LockDocument()) { ObjectId entityID; using (var tr = DOC.TransactionManager.StartTransaction()) { var modelspace = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(DOC.Database), OpenMode.ForWrite); // Circle circ = new Circle(Point3d.Origin, Vector3d.ZAxis, 100.0); entityID = modelspace.AppendEntity(line); tr.AddNewlyCreatedDBObject(line, true); tr.Commit(); } //**************begion to maptrim Util.PrintLn("begion to maptrim "); CWriteLog.Msg(targetPath, "begin to maptrim "); app.ActiveDocument.SendCommand("_.MAPTRIM\nS\nlast\nN\nN\nO\nY\nN\nR\nY\n\n"); CWriteLog.Msg(targetPath, " finish maptrim "); Util.PrintLn("finish maptrim "); CWriteLog.Msg(targetPath, "delete polyline "); DeleleEnity(entityID); CWriteLog.Msg(targetPath, "save ......."); string saveFolder = targetPath + "\\" + "outPut"; if (!System.IO.Directory.Exists(saveFolder)) { System.IO.Directory.CreateDirectory(saveFolder); } string filename = saveFolder + "\\" + MapCode + ".dwg"; ; app.ActiveDocument.SendCommand("_.SAVEAS\n2004\n" + filename + "\nY\n\n");
everytime  I  get  the error  at  "
Replies (21)
Message 2 of 22
ActivistInvestor
SendCommand() is asynchronous, which means that the commands that you pass it do not execute until after your code exits and returns control to AutoCAD.
You cannot do batch scripting this way. If you have 'thousands of dwg files', you will probably need to start and shutdown AutoCAD for each one, or every 10 or so files, but in order to execute commands your code must run in the document execution context, or you must find a way to wait until the command has finished (using an event possibly) before you resume processing the file.
Batch processing is best done by controlling the entire process from an out-of-process ActiveX client. You can write the code that processes each file in .NET, and then expose it as a command that would be started using SendCommand() from the out-of-process controller. It must then wait until the command has finished before closing the file and opening the next one.
  using System;
using System.Linq;
using System.Text;
using AutoCAD;
Message 3 of 22
Juergen_Becker
I'm using a DLLImport to define a method which calls internals.
[DllImport("accore.dll",
 CharSet = CharSet.Unicode,
 CallingConvention = CallingConvention.Cdecl,
 EntryPoint = "acedCmd")]
public static extern int acedCmd(IntPtr vlist);
 EntryPoint = "acedCmdS")]
public static extern int acedCmdS(System.IntPtr vlist);
This is an example:
m_ResultBuffer = new ResultBuffer();
m_ResultBuffer.Add(new TypedValue(5005, "_.SAVEAS"));
m_ResultBuffer.Add(new TypedValue(5005, m_ResultBuffer.Add(new TypedValue(5005, m_FileName));
if (System.IO.File.Exists(m_FileName) == true)
     m_ResultBuffer.Add(new TypedValue(5005, "_YES"));
if (m_ACADVersionDouble >= 21)
     acedCmdS(m_ResultBuffer.UnmanagedObject);
else if (m_ACADVersionDouble >= 19 && m_ACADVersionDouble <= 19.1)
     acedCmd(m_ResultBuffer.UnmanagedObject);
This works fine in a command, you don't have to wait or something like that.
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
Message 4 of 22
ActivistInvestor
There is no need to call directly to acedCmd() or acedCmdS() because they are called by the Editor.Command() method.
The Editor.Command() method is a managed wrapper for acedCmdS():
Here is the source code of Editor.Command():
// Autodesk.AutoCAD.EditorInput.Editor
public unsafe void Command(params object[] parameter)
   resbuf* ptr = null;
   try
      ptr = (resbuf*)Marshaler.ObjectsToResbuf(parameter).ToPointer();
      Interop.CheckAds(<Module>.acedCmdS((resbuf*)ptr, false, null));
   finally
      if (ptr != null)
         <Module>.acutRelRb(ptr);
This is an example:
Regards Jürgen
Message 5 of 22
thank you for your reply!
i simply my processing,i open template ,then  add a  circle  ,then  save  and close, one by one
my code like  this,but is run  wrong
how to modify ?
        [CommandMethod("MyOF")]
        public void op()
            string filedia = Application.GetSystemVariable("filedia").ToString();
            DocumentCollection docsMgr = Application.DocumentManager;
            for (int i = 0; i < 100; i++)
                try
                    Document doc = docsMgr.Open("C:\\template2000.dwg", false);
                    docsMgr.MdiActiveDocument = doc;
                    using (doc.LockDocument())
                        ObjectId entityID;
                        using (var tr = doc.TransactionManager.StartTransaction())
                            var modelspace = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(doc.Database), OpenMode.ForWrite);
                            entityID = modelspace.AppendEntity(circ);
                            tr.AddNewlyCreatedDBObject(circ, true);
                            tr.Commit();
                            doc.UserData.Add("EntityId", entityID);
                        doc.Editor.Command("_.ZOOM", "_object", doc.UserData["EntityId"], "");
                        doc.Editor.Command("_.SAVEAS", "2004", "C:\\ee" + i + ".dwg", "Y");
                   doc.Editor.Command("_.CLOSE");
                catch (System.Exception ee)
                    Util.PrintLn("error" + ee.Message.ToString());
Message 6 of 22
_gile
To be able to switch between documents, you have to use the CommandFlags.Session, but this sets your command in the application context and you can only use Editor.Command() in the document context.
For batch scripting files, you should have a look at ScriptPro.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 22
I know if i use the  commandflag.session , ed.command  does't work.
how do i send command synchronous in commandflag.session,  so that  i can  operate  dwg  one by one!
Message 8 of 22
can you give me  a  whole example code?
Message 9 of 22
_gile
As far as I know there's no way to synchronously call commands in application context, but I may be wrong.
Gilles Chanteau
GileCAD
GitHub
Message 10 of 22
is there no way  to solve my problem?
I just  want  to  do  that   open a  template dwg file  ,then  send a  command  to  add a  circle  ,then  save  and close, one by one
Message 11 of 22
Juergen_Becker
 and save the Hi,
why do you open the drawin ginto the editor? Thats Needs time.
What about this?
m_DataBase = new Database(false, true);
m_DataBase.ReadDwgFile(m_DrawingPath + @"\" + m_Name + ".DWG",
      true,
      string.Empty);
m_DataBase.CloseInput(true);
This does'nt open the drawing in the Editor and it's much faster. After that you can add your circle or what ever you want and save the drawing.
m_Name is the drawing Name put your drawing Name into a list (System.Collections.Generic.List<string>).
BTW: You don't need any SendCommands or what ever.
Regards Jürgen
Thanks.
Jürgen A. Becker
Building Services
CAD-Becker.de
Message 12 of 22
i have try this  method,
the problem is that  i have thousands of  dwg  file to do ,the  memory  of  ACAD.EXE   will  increase  quickly!
how to  free  the memory  when database close?
Message 13 of 22
_gile
If you only want to draw a circle (or anything else which can be done by a command), you can use SendStringtoExecute.
        [CommandMethod("MyOF", CommandFlags.Session)]
        public void op()
            string filedia = Application.GetSystemVariable("FILEDIA").ToString();
                try
                    string filename = "C:\\ee" + i + ".dwg";
                    if (System.IO.File.Exists(filename))
                        System.IO.File.Delete(filename);
                    doc.SendStringToExecute("FILEDIA 0 ", false, false, false);
                    doc.SendStringToExecute("_.CIRCLE 0,0 100.0 ", false, false, false);
                    doc.SendStringToExecute("_.ZOOM _object _last  ", false, false, false);
                    doc.SendStringToExecute("_.SAVEAS 2004 " + filename + "\n", false, false, false);
                    doc.SendStringToExecute("_.CLOSE ", false, false, false);
                    doc.SendStringToExecute("FILEDIA " + filedia + " ", false, false, false);
But, IMO, for this kind of scripting, you should have a look at the accoreconsole.
Gilles Chanteau
GileCAD
GitHub
Message 14 of 22
_gile
As @ActivistInvestor said, if you have thousands of files to do, you should stop and restart AutoCAD from time to time.
It seems to me that ScriptPro handles this.
Gilles Chanteau
GileCAD
GitHub
Message 15 of 22
Juergen_Becker
What I don't understand is that you necessarily loaded the document into the Editor.
It is not necessary for such a task.
Use ReadDwgFile to open the darwing into the Memory. Close the Input. Do what you want with the drawing database, save it and Close the drawing.
I did that with 6000 drawings without any problems.
You can use AutoCAD to that or mentionied above with the AutoCAD Core Console and forget all the SendCommands.
Thanks.
Jürgen A. Becker
Building Services
CAD-Becker.de
Message 16 of 22
_gile
Here's a simple Console Application which uses the Core Console.
Change the core console path as needed.
using System.Diagnostics;
using System.IO;
namespace AcCoreConsoleSample
    class Program
        static void Main(string[] args)
            Run();
        const string coreConsolePath = @"C:\Program Files\Autodesk\AutoCAD 2013\accoreconsole.exe";
        cons string scriptPath = @"C:\Temp\CoreConsoleScript.scr";
static void Run() { for (int i = 0; i < 10; i++) { string filename = "C:\\Temp\\ee" + i + ".dwg"; if (File.Exists(filename)) File.Delete(filename); using (var writer = new StreamWriter(scriptPath, false)) { writer.WriteLine("_.CIRCLE 0,0 100.0"); writer.WriteLine("_.ZOOM _object _last\n"); writer.WriteLine("_.SAVEAS 2004"); writer.WriteLine(filename); } string args = "/s " + scriptPath; var startInfo = new ProcessStartInfo(coreConsolePath, args); startInfo.WindowStyle = ProcessWindowStyle.Normal; var process = Process.Start(startInfo); process.WaitForExit(); } File.Delete(scriptPath); } } }
Gilles Chanteau
GileCAD
GitHub
Message 17 of 22
_gile
You can also easily parallelize the process to run in parallel as many consoles as available cores.
using System.IO;
    class Program
            RunParallel();
        static void RunParallel()
            Parallel.For(0, 10, i =>
                string scriptPath = @"C:\Temp\CoreConsoleScript_" + i + ".scr";
Gilles Chanteau
GileCAD
GitHub
Message 18 of 22
_gile
Because the OP wants to be able to run commands (he talked about the MAPTRIM command in the first post).
Gilles Chanteau
GileCAD
GitHub
Message 19 of 22
ActivistInvestor
Use ReadDwgFile .....
The ZOOM command cannot be used on a drawing that's not open in the Editor.
Look at the code again. Do you see "Command("._ZOOM, ...) ????
If you are going to make such statements, then you should also show how to zoom to an object in a drawing that's not open in the editor.
While it's not impossible, it's not so simple a task, so before you tell others to use ReadDwgFile(), you have to show them how to do the task that you say doesn't require the drawing to be open in the editor.
So please show the OP how to zoom to an object without opening the drawing in the editor, and while you're at it, also show how to generate a correct thumbnail preview for the DWG file without opening it in the editor.
Message 20 of 22
hi
you said "Use ReadDwgFile to open the darwing into the Memory.... did that with 6000 drawings without any problems.",
if  you  read  6000 drawings  into  memory , how  large    memory  occupy with  acad.exe  at last  ?
do  you done  some thing to  free  memory?
can you  solve the  problem  in   another topic? https://forums.autodesk.com/t5/net/database-free-the-memory/m-p/7623187#M56334
