Announcements
selectionfilter select object by layer, layer name contains #, selectionresult got error
use the following code to select objects on layer, layername contains #, selectionresult ERROR
TypedValue[] tvs = new TypedValue[]
new TypedValue((int)DxfCode.Operator, "<and"),
new TypedValue((int)DxfCode.LayerName,  layerName  ),
new TypedValue((int)DxfCode.Operator, "and>")
SelectionFilter filter = new SelectionFilter(tvs);
ObjectId[] objIds;
PromptSelectionResult psr = doc.Editor.SelectAll(filter);
please anyone can help
Thank you
_gile
Selection filters use wildcard patterns and # is wildcard charater.
You have to prefix the # with a reverse quote (`#) in the filter pattern.
layerName.Replace("#", "`#")
PS : using special characters in layer names, block names, ... is not a good practice.
Gilles Chanteau
GileCAD
GitHub
THANK YOU VERY MUCH Gilles, you made my day, very much appreciate
