I would like to test your functions, but not until I have my own working. I've gotten far enough with mine that I
really want to follow through with it to see how it works out, even if it turns out to not be as effective or
efficient as yours. As I mentioned I'm new to .Net, and this is proving to be a very educational exercise.
I look forward to seeing how they compare. My address is in the header; just change the obvious.
James Allen
Malicoat-Winslow Engineers, P.C.
Columbia, MO
wrote in message news:5697474@discussion.autodesk.com...
/*Thank you. I'm currently thinking along different lines (though not getting much time to put on it). I would need
this to work with xrefs and am afraid that something involving explode may be too much for xrefs or large selection
areas. I haven't ruled it out but am pursuing other possibilities first.*/
James;
If you want to run your own tests with the functions I wrote, I can e-mail them to you.
Running the tests on simple blocks (using a large number on the screen view), it works very fast.
I will try to add the xrefs, and see how that might work - I might need something like this.
