Select blocks in current paperspace
miketurpin_innovatingfutures
Hi All,
Bit of a c# newbie so please excuse me if this is an obvious question.
Wrtitng some code where i want to select all blocks in the current paperspace.
I know i can use this code to select all blocks in all paperspace but wondered if there is a way to refine it to do what i want to do?
TypedValue[] filList = new TypedValue[2]
new TypedValue(67,1),new TypedValue(0,"INSERT")
SENL1362
there is only one (currrent) Paperspace, so 67==1 select block REFERENCES for the active Layout only.
SENL1362
You can get the block the selected entity belongs to you using the following :
                foreach (ObjectId entId in selectedIds)
                    Entity ent = (Entity)tr.GetObject(entId, OpenMode.ForRead);
                    BlockTableRecord parentBlk = (BlockTableRecord)tr.GetObject(ent.OwnerId, OpenMode.ForRead);
                    ed.WriteMessage("\n DxfName={0}, EntType={1}, Handle={2}, Layer={3}, Block={4}", entID.ObjectClass.DxfName,ent.GetType().ToString() , ent.Handle.ToString(), ent.Layer.ToString(), parentBlk.Name);
The block is the modelspace or the Block for the (Current) Layout (layout.BlockTableRecordId)
SENL1367,
Thanks for the reply but not sure i understand.
I have a drawing with 5 drawing sheets (in 5 paperspaces) and i want to select all of the blocks in the paperspace the user is currently viewing.
The (67,1) seems to select from all 5 paperspaces not just the current one.
Thanks again for your help
Mike
_gile
You can use the layout name in a selection filter with 410 dxf code:
    new TypedValue(0,"INSERT"),
    new TypedValue(410, "Layout1")
 If you want to get the current layout name, you can use the CTAB system variable.
string ctab =
    (string)HostApplicationServices.WorkingDatabase.GetSystemVariable("CTAB");
    new TypedValue(410, ctab)
Gilles Chanteau
GileCAD
GitHub
