Save a string value in dwg file
abdul.haseeb
abdul.haseeb
Hi all,
I need to save a string value in dwg file say "something to be saved".
then when I needed I should get this value.
Please kindly help to get this.
_gile
You can use an Xrecord in a DBDictionary to store the string.
You'll find many example in this forum, here's one.
Gilles Chanteau
GileCAD
GitHub
abdul.haseeb
Thanks for this reply.
But in need something different....
Like variable while are already available in DWG
USERS1-5
Actually I want to save it in VB.net and want to get the same in ObjectARX c++ and vice versa
_gile
USERS1-5 is not saved in the drawing, this is why you have to use an Xrecord (or some Extended data attached to an unerasable object as the layer "0").
Xrecords (and xdata) can be accessed by any AutoCAD programation environment (AutoLISP, COM, .NET, ObjectARX).
"ABDUL_HASEED" and an Xrecord named "StringValue" which only contains one string.
        public void SaveStringInCurrentDrawing(string str)
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            using (doc.LockDocument())
            using (var tr = new OpenCloseTransaction())
                var nod = (DBDictionary)tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead);
                DBDictionary dict;
                if (nod.Contains("ABDUL_HASEEB"))
                    dict = (DBDictionary)tr.GetObject(nod.GetAt("ABDUL_HASEEB"), OpenMode.ForRead);
                else
                    dict = new DBDictionary();
                    nod.UpgradeOpen();
                    nod.SetAt("ABDUL_HASEEB", dict);
                    tr.AddNewlyCreatedDBObject(dict, true);
                Xrecord xrec;
                if (dict.Contains("StringValue"))
                    xrec = (Xrecord)tr.GetObject(dict.GetAt("StringValue"), OpenMode.ForWrite);
                else
                    xrec = new Xrecord();
                    if (!dict.IsWriteEnabled) tr.GetObject(dict.ObjectId, OpenMode.ForWrite);
                    dict.SetAt("StringValue", xrec);
                    tr.AddNewlyCreatedDBObject(xrec, true);
                xrec.Data = new ResultBuffer(new TypedValue(1, str));
                tr.Commit();
        public string GetSavedStringInCurrentDrawing()
                if (!nod.Contains("ABDUL_HASEEB"))
                    return null;
                var dict = (DBDictionary)tr.GetObject(nod.GetAt("ABDUL_HASEEB"), OpenMode.ForRead);
                if (!dict.Contains("ABDUL_HASEEB"))
                    return null;
                var xrec = (Xrecord)tr.GetObject(dict.GetAt("StringValue"), OpenMode.ForWrite);
                if (xrec.Data == null)
                    return null;
                return xrec.Data.AsArray()[0].Value.ToString();
Gilles Chanteau
GileCAD
GitHub
stefan.hofer
you can also use custom properties:
thisDrawing.SummaryInfo.AddCustomInfo("MyKey", "MyValue");
and
string value = "";
thisDrawing.SummaryInfo.GetCustomByKey("MyKey", out value);
thisdrawing:
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
thisDrawing = (AcadDocument)acApp.DocumentManager.MdiActiveDocument.GetAcadDocument();
