run method created in lisp con c#.net
Hello everyone
I have created many method in lisp. And I'm trying to run a method that has as parameters 2 points and a string
I am trying to run the function (loaded in autocad) with code in .net
And I couldn't load the run to the method . I can only run create method for me that don't need parameters.
question:
1)Can I call routines with parameters created by me using c # .net code?
2)What would be the correct way to call?
regards
_gile
hi,
You have to use the Application.Invoke() method. See these topics:
https://forums.autodesk.com/t5/net/unable-to-find-an-entry-point-in-dll-acad-exe/m-p/5527242/highlig...
https://forums.autodesk.com/t5/net/how-to-pass-selection-set-to-lisp-command/m-p/8760502#M62469
In you case:
            var args = new ResultBuffer(
                new TypedValue((int)LispDataType.Text, "c:wrapper_draw_pl"),
                new TypedValue((int)LispDataType.Point3d, new Point3d(-11452.0, 3197.0, 0.0)),
                new TypedValue((int)LispDataType.Point3d, new Point3d(-11452.0, 3297.0, 0.0)),
                new TypedValue((int)LispDataType.Text, "A"));
            Application.Invoke(args);
But attentively read @dgorsman 's advice here:
https://forums.autodesk.com/t5/net/call-autolisp-function-from-c-code/td-p/5521845
Gilles Chanteau
GileCAD
GitHub
Thank you very much for the code and the links.
It is what I was looking for.
regards
