Required codign in .net
waseefur.rahman
Message 1 of 14
waseefur.rahman
I am a .net learner,
I want to create a coding to copy 3D Solid in Same place with different layer,
(i.e) I am having object in Layer 1,
coding should ask to select object,
then create a copy in layer 2 in same place.
Could any provide me a coding on this?
Thanks & Regards
Accepted solutions (3)
Replies (13)
Message 2 of 14
The following function can clone any Entity and change i'ts layer.
I also use an additional function to check if the entered layer exists.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Customization;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using System;
using System.Collections.Generic;
using System.Configuration;
using System.Diagnostics;
using System.IO;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Application = Autodesk.AutoCAD.ApplicationServices.Application;
namespace AutodeskAppStoreTesting
    public class Commands : IExtensionApplication
       [CommandMethod("ChangeLayerOfSelected", CommandFlags.UsePickSet)]
        public static void ChangeLayerOfSelected()
                        Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            ObjectIdCollection Entities = null;
            var PSelection = ed.SelectImplied();
            if (PSelection.Status != PromptStatus.OK || PSelection.Value.Count == 0)
                var Selection = ed.GetSelection(new PromptSelectionOptions()
                    MessageForAdding = "\nSelect Entities to Change Layer",
                if (Selection.Status != PromptStatus.OK) return;
                Entities = new ObjectIdCollection();
                Entities.AddRange(Selection.Value.GetObjectIds());
            else
                Entities.AddRange(PSelection.Value.GetObjectIds());
            string LayerName = "";
            var LayerNamePrompt = ed.GetString(new PromptStringOptions("\nEnter Layer Name"));
            if (LayerNamePrompt.Status != PromptStatus.OK) return;
            LayerName = LayerNamePrompt.StringResult;
            MakeSureLayerExists(LayerName);
            using (Transaction tr = db.TransactionManager.StartTransaction())
                foreach (ObjectId n in Entities)
                    Entity En = tr.GetObject(n, OpenMode.ForWrite) as Entity;
                    if (En == null) continue;
                    BlockTableRecord Owner = tr.GetObject(En.OwnerId, OpenMode.ForWrite) as BlockTableRecord;
                    if (Owner == null) continue;
                    string OldLayerName = En.Layer;
                    using (Entity NewEn = En.Clone() as Entity)
                        NewEn.Layer = LayerName;
                        Owner.AppendEntity(NewEn);
                        tr.AddNewlyCreatedDBObject(NewEn,true);
                    ed.WriteMessage("\nObject of type " + n.ObjectClass.Name + " has been duplicated with its layer changed from \"" + OldLayerName + "\" to \"" + LayerName + "\"");
                tr.Commit();
        private static void MakeSureLayerExists(string LayerName)
                var LayerTab = tr.GetObject(db.LayerTableId, OpenMode.ForRead) as LayerTable;
                if (!LayerTab.Has(LayerName))
                    using (var NewLayer = new LayerTableRecord())
                        NewLayer.Name = LayerName;
                        LayerTab.UpgradeOpen();
                        LayerTab.Add(NewLayer);
                        tr.AddNewlyCreatedDBObject(NewLayer, true);
                tr.Commit();
    public static class ObjectIdCollectionExtensions
        public static void AddRange(this ObjectIdCollection a, ObjectId[] Range)
            foreach (var n in Range)
                a.Add(n);
Message 3 of 14
waseefur.rahman
Great..
Many thanks,
Could you provide this coding in vb.net please..
Also in coding you Said it's changing the selection to New layer.
I will brief my question
When user selects the object,
Then coding need to create a copy of object to New layer.
Also the selection object should be in same place.
(i.e) We can take the coping & pasting pick point as same (0,0,0)
Message 4 of 14
The posted code will create a copy in the same position of the selected objects to only then change the layer of the new objects.
ALthough VB.NET and C# have different syntaxes, they can be easily translated with almost no problem using a simple code converter.
Personally I prefer Telerik's. Web-based free and pretty accurate...
Below the converted code:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Customization
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Imports System.Collections.Generic
Imports System.Configuration
Imports System.Diagnostics
Imports System.IO
Imports System.Linq
Imports System.Text
Imports System.Windows.Forms
Imports Application = Autodesk.AutoCAD.ApplicationServices.Application
Namespace AutodeskAppStoreTesting
    Public Class Commands
        Implements IExtensionApplication
        <CommandMethod("ChangeLayerOfSelected", CommandFlags.UsePickSet)> _
        Public Shared Sub ChangeLayerOfSelected()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            Dim Entities As ObjectIdCollection = Nothing
            Dim PSelection = ed.SelectImplied()
            If PSelection.Status <> PromptStatus.OK OrElse PSelection.Value.Count = 0 Then
                Dim Selection = ed.GetSelection(New PromptSelectionOptions() With { _
                    Key .MessageForAdding = vbLf & "Select Entities to Change Layer" _
                If Selection.Status <> PromptStatus.OK Then
                    Return
                Entities = New ObjectIdCollection()
            Else
            Dim LayerName As String = ""
            Dim LayerNamePrompt = ed.GetString(New PromptStringOptions(vbLf & "Enter Layer Name"))
            If LayerNamePrompt.Status <> PromptStatus.OK Then
                Return
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                For Each n As ObjectId In Entities
                    Dim En As Entity = TryCast(tr.GetObject(n, OpenMode.ForWrite), Entity)
                    If En Is Nothing Then
                        Continue For
                    Dim Owner As BlockTableRecord = TryCast(tr.GetObject(En.OwnerId, OpenMode.ForWrite), BlockTableRecord)
                    If Owner Is Nothing Then
                        Continue For
                    Dim OldLayerName As String = En.Layer
                    Using NewEn As Entity = TryCast(En.Clone(), Entity)
                        tr.AddNewlyCreatedDBObject(NewEn, True)
                    End Using
                    ed.WriteMessage((Convert.ToString((Convert.ToString(vbLf & "Object of type " + n.ObjectClass.Name + " has been duplicated with its layer changed from """) & OldLayerName) + """ to """) & LayerName) + """")
                Next
                tr.Commit()
            End Using
        End Sub
        Private Shared Sub MakeSureLayerExists(LayerName As String)
                Dim LayerTab = TryCast(tr.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable)
                If Not LayerTab.Has(LayerName) Then
                    Using NewLayer = New LayerTableRecord()
                        tr.AddNewlyCreatedDBObject(NewLayer, True)
                    End Using
                tr.Commit()
            End Using
        End Sub
    End Class
    Public NotInheritable Class ObjectIdCollectionExtensions
        Private Sub New()
        End Sub
        <System.Runtime.CompilerServices.Extension> _
        Public Shared Sub AddRange(a As ObjectIdCollection, Range As ObjectId())
            For Each n As var In Range
                a.Add(n)
            Next
        End Sub
    End Class
End Namespace
'Service provided by Telerik (www.telerik.com)
'Conversion powered by NRefactory.
'Twitter: @telerik
'Facebook: facebook.com/telerik
Message 5 of 14
waseefur.rahman
Many Thanks,
I am getting errors, attached image,
Could please tell me what to do?
Message 6 of 14
waseefur.rahman
i have tried with this code,
its copying the selected object in same layer with different color
could you tell me in this code how paste the object in different layer.
Also attached a dwg file, shows the output required
<CommandMethod("cp")>
Public Shared Sub CopyMove()
Dim peo As New PromptEntityOptions(vbLf & "Select object:")
Dim per As PromptEntityResult = ed.GetEntity(peo)
If per.Status <> PromptStatus.OK Then
Return
Dim startPT As Point3d = per.PickedPoint
Dim EndPT As Point3d = per.PickedPoint
Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
Dim sourceId As ObjectId = per.ObjectId
Dim EntitySource As Entity = CType(tr.GetObject(sourceId, OpenMode.ForWrite), Entity)
Dim ids As New ObjectIdCollection()
ids.Add(sourceId)
db.DeepCloneObjects(ids, db.CurrentSpaceId, New IdMapping, False)
Dim EntityCopy As Entity = CType(tr.GetObject(ids(0), OpenMode.ForRead), Entity)
EntityCopy.UpgradeOpen()
EntityCopy.TransformBy(Matrix3d.Displacement(startPT.GetVectorTo(EndPT)))
EntityCopy.ColorIndex = 2
tr.Commit()
End Using
End Sub
Message 7 of 14
In order to make the method I've sent work you must add this Extensions Class to the same namespace:
        Private Sub New()
        End Sub
                a.Add(n)
            Next
        End Sub
    End Class
If you want to use the method you've sent you just need a few adjustments:
Return
Return
ids.Add(sourceId)
EntityCopy.Layer = LayerName
tr.Commit()
End Using
End Sub
Private Shared Sub MakeSureLayerExists(LayerName As String) Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Using tr As Transaction = db.TransactionManager.StartTransaction() Dim LayerTab = TryCast(tr.GetObject(db.LayerTableId, OpenMode.ForRead), LayerTable) If Not LayerTab.Has(LayerName) Then Using NewLayer = New LayerTableRecord() NewLayer.Name = LayerName LayerTab.UpgradeOpen() LayerTab.Add(NewLayer) tr.AddNewlyCreatedDBObject(NewLayer, True) End Using End If tr.Commit() End Using End Sub
Message 8 of 14
waseefur.rahman
i have also tried with this coding, but didn't getting solution
also attached a error snap.
Imports Autodesk.AutoCAD.Interop
Public ReadOnly Property ThisDrawing() As AcadDocument
Get
Return Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument)
End Get
End Property
Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
Dim tu As AcadUtility
tu = ThisDrawing.Utility
ThisDrawing.SendCommand("COPYTOLAYER" & vbCr & tu.Get(, "Select objects to copy") & vbCr & "N" & vbCr & "Layer2" & vbCr)
End Sub
Message 9 of 14
waseefur.rahman
Many Thanks,
it works...
Could you Please tell me how to do it with "COPYTOLAYER" command in coding
I have tried with this code but it dosent work
Imports Autodesk.AutoCAD.Interop.Common
Get
End Get
End Property
Private Sub Create_Copy_Click(sender As Object, e As EventArgs) Handles Create_Copy.Click
ThisDrawing.SendCommand("COPYTOLAYER" & vbCr & tu.GetEntity & vbCr & "N" & vbCr & "Cutback Extruction" & vbCr)
End Sub
Message 10 of 14
_gile
SendCommand expects a string as argument and there're none implicit cast from AcadUtils.GetEntity() returned value and the String type.
If your're targetting AutoCAD 2015 or later, you can use the Editor.Command() method, for prior versions, you can use the Tony Tanzillo's wrapper for the non public RunCommand() method which works the same way.
Assuming the dialog is shown as modal dialog and the "Cutback Extruction" layer already exists in the document.
C#
        private void button1_Click(object sender, EventArgs e)
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var selection = ed.GetSelection();
            if (selection.Status == PromptStatus.OK)
                ed.Command("_COPYTOLAYER", selection.Value, "", "Cutback Extruction", "");
VB
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim doc As Document = AcApp.DocumentManager.MdiActiveDocument
        Dim selection As PromptSelectionResult = ed.GetSelection()
        If selection.Status = PromptStatus.OK Then
    End Sub
But, as shown by @Anonymous, it's not so difficult to mimic the "COPYTOLAYER" command.
C#
        private void button2_Click(object sender, EventArgs e)
            var db = doc.Database;
            if (selection.Status == PromptStatus.OK) return;
            try
                var ids = new ObjectIdCollection(selection.Value.GetObjectIds());
                var mapping = new IdMapping();
                db.DeepCloneObjects(ids, SymbolUtilityServices.GetBlockModelSpaceId(db), mapping, false);
                using (var tr = db.TransactionManager.StartTransaction())
                    foreach (IdPair item in mapping)
                        if (item.IsCloned && item.IsPrimary)
                            var entity = (Entity)tr.GetObject(item.Value, OpenMode.ForWrite);
                            entity.Layer = "Cutback Extruction";
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage("\n" + ex.Message);
VB
    Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
        If selection.Status <> PromptStatus.OK Then
            Return
        Try
            Dim ids As ObjectIdCollection = New ObjectIdCollection(selection.Value.GetObjectIds())
            Dim mapping As IdMapping = New IdMapping()
            db.DeepCloneObjects(ids, SymbolUtilityServices.GetBlockModelSpaceId(db), mapping, False)
                For Each item As IdPair In mapping
                    If item.IsCloned AndAlso item.IsPrimary Then
                        Dim entity As Entity = DirectCast(tr.GetObject(item.Value, OpenMode.ForWrite), Entity)
                Next
                tr.Commit()
            End Using
        Catch ex As Autodesk.AutoCAD.Runtime.Exception
            ed.WriteMessage(vbLf + ex.Message)
        End Try
    End Sub
Gilles Chanteau
GileCAD
GitHub
Message 11 of 14
waseefur.rahman
Hi gile,
Many thanks for Your response,
The code by chavesgalinari, has been working Fine
But I have been trying the above through "COPYTOLAYER" command in coding.
while running code I got this error attached (Capture 23)
could you please guide what to do to achive it
Message 12 of 14
_gile
In which context do you run this code? Editor.Command() must be called in document context.
In other words, how do you call this code? from a dialog? if so, the dialog have to be shown as Modal dialog.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 14
waseefur.rahman
Sorry,
I didn't get you,
Are you asking me how I am running this code?
I have been running this code through from, where I am having a button to call this code.
Message 14 of 14
_gile
How do you display this form? as modal or modeless?
If you're using:
form.Show()
or, better (see this thread😞
Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(form)
you use a modeless dialog which does not execute in document context, so you cannot directly use Editor.Command() from this kind of dialog.
On the other hand if you use (not so good):
form.showDialog()
or (better):
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(form)
you use a modal dialog which executes in document context and so can call Editor.Command() directly.
Gilles Chanteau
GileCAD
GitHub
