RemoveItems - Does it work in VB.NET??
Could anyone show an example of removing a subset of entities from an existing selection set via RemoveItems?
I am starting to think it is not possible. I find many examples of VBA solutions, but when I try to convert them to VB.NET...RemoveItems treats the object SS as a method rather than a "target" but putting the element array in parenthesis.
If for some reason this functionality is not available to VB.NET users...what is the solution for removing a subset of entities from a selection set? (...or simulating this action.)
Or maybe I don't have any idea what the heck I'm doing...
Any help gratefully received.
This is what I have done to remove items from a selection set using the
ActiveX API through vb.net:
Try
'build a selectionset filtering first for appname xdata
GeoSS = CreateSelectionSet(AcadApp, "XdataSelectionSet")
gpCode(0) = -3
gpCode(1) = 1001
dataValue(1) = "CTTB"
GeoSS.Select(AcSelect.acSelectionSetAll, , , gpCode, dataValue)
For Each XdataObject In GeoSS
XdataObject.GetXData("", xtypeOut, xdataOut)
If xdataOut(1) = TopGUID Then
XdataObject.Delete()
'Stop
Next
AcadApp.Update()
Catch ex As Exception
MsgBox("Failed to erase geometry.")
End Try
Nevermind. I misunderstood the question. I am deleting from the
drawing here, not removing from the selection set.
Sorry.
> Try
> gpCode(0) = -3
> gpCode(1) = 1001
> End If
> 'Stop
> Next
> AcadApp.Update()
> End Try
Did you checked your post in VBA NG? Someone has pointed out the logical
error in your code while you think it is language problem (with bracket or
not around the parameter you paased to a method). The array you passed to
RemoveItems() method is wrong, not the bracket (yes, VB.NET use () around
the parameters passed, while VB/VBA does not unless you preceded with
"CALL").
"PellaCAD" wrote in message news:5911310@discussion.autodesk.com...
in parenthesis.
