REGEN3 via API
REGEN3 via API
phliberato
Message 1 of 9
REGEN3 via API
phliberato
Is there some way to call this Autocad command (REGEN3) by way of API .NET?
Replies (8)
Message 2 of 9
MateusMaciel
Document doc = Application.DocumentManager.MdiActiveDocument;
doc.Editor.Regen();
mateustilapa@gmail.com
Message 3 of 9
phliberato
Message 4 of 9
MateusMaciel
@phliberato sorry,
You have tried the following:
doc.SendStringToExecute("REGEN3\n", true, false, false);
In this case, it would run via a command prompt;
Message 5 of 9
phliberato
I have already used this approach as workaround, but I'm looking for some API function approach.
Message 6 of 9
ChristianBlei
Hi Pedro,
I have a situation where I also need Regen3.
Did you find an API eqivalent to the command?
best regards to BeHo
Christian
Christian Blei
CBT Christian Blei Tools
christianblei.de
youtube.com/channel/UCxjA_NbeScQy9C0Z1xjwXpw
Message 7 of 9
Alexander.Rivilis
Some years ago I received  next code from ADN DevHelp:
Autodesk.AutoCAD.GraphicsSystem.Manager mpManager = doc.GraphicsManager;
Autodesk.AutoCAD.GraphicsSystem.KernelDescriptor descriptor =
                  new Autodesk.AutoCAD.GraphicsSystem.KernelDescriptor();
descriptor.addRequirement(Autodesk.AutoCAD.UniqueString.Intern("3D Drawing"));
Autodesk.AutoCAD.GraphicsSystem.GraphicsKernel kernal =
                  Autodesk.AutoCAD.GraphicsSystem.Manager.AcquireGraphicsKernel(descriptor);
Autodesk.AutoCAD.GraphicsSystem.Model Model = mpManager.GetDBModel(kernal);
Model.Invalidate(Autodesk.AutoCAD.GraphicsSystem.InvalidationHint.InvalidateAll);
Application.DocumentManager.MdiActiveDocument.Editor.Regen();
You can try it.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 8 of 9
phliberato
Hi @ChristianBlei ,
Good to see you here!
I didn't find an API eqivalent to this Regen3 command. However I noticed that in CAD recent versions the Regen command works well instead of Regen3 but I don't use the Regen function of Editor class, because it doesn't update the Project Explorer of Advance Steel. I submitted a pull request for the AS Dynamo plugin that I used this approach.
https://github.com/DynamoDS/Dynamo-Advance-Steel/pull/73/files
Maybe in your case the code that @Alexander.Rivilis sent it will work to you.
Best regards to Düsseldorf
Message 9 of 9
ChristianBlei
Hi Alexander,
thank you for sharing this snippet. It fixed the problems I have with representation of Advance Steel parts in 3D Visual styles, Conceptual ,e.g....
Do you recall differences to what Regen3 is doing?
best regards,
Christian
Christian Blei
christianblei.de
