.NET
Reg. How to make installer from Class Library Project
3 REPLIES 3
323 Views, 3 Replies
Hi All, I have created one class library project using .NET API. So now I want to convert that project into the Setup project means I want to make installer for it. After that it installed, I want my plug in in the ribbon menu. So can anyone tell me how to do this ?
3 REPLIES 3
Haha,
Never has someone asked for so much with so little words.
1.  AutoCad 2013+ Has an automatic loader.  Or you can add a registry entry to start it up, or a script file from a desktop shortcut.
2.  If you want to distribute it as an installer package I use MSI Factory.  It's not free but it's very good and easy to use.
3.  I have found lots of ribbon getting started answers on here.  If you mean add it to the AutoCad Ribbon i am not sure, but do a search on here there are lots of good examples.
I'm sure my answers can be improved, but good luck.
StephenPreston
I second quigs's suggestion of using Autoloader if your deployment is for AutoCAD 2012+ (not 2013+, quigs :-)). Google for Autoloader for more info. Using this feature, you only have to copy files to the correct location - instead of writing a complicated installer that has to check the regsitry to determine which AutoCAD vertical/version/locale is present. Autloader can also automatically load a partial CUI for your application - very easy way to deploy your UI.
Cheers,
Stephen Preston
Autodesk Developer Network
Forma Design Contest
AutoCAD Beta
