Announcements
Problem With Rectangular Array Autocad. Net
alex.kilworth
alex.kilworth
Hi All
I'm New to C# and working on a beginner project. The project is essentially asking the user a set of questions which drive integers to produce a drawing template. I would like Polylines P4 & P5 to be arrayed in the x axis but not in the Y axis. please see attached picture and code. Thanks
public class CreateElevation
    Point2d PolarPoints(Point2d pPt, double dAng, double dDist)
        return new Point2d(pPt.X + dDist * Math.Cos(dAng),
                                pPt.Y + dDist * Math.Sin(dAng));
    [CommandMethod("DrawElevation")]
    public void DrawElevation()
        int Risers = 0, RiserWidth = 0, Floors = 0, FloorHeigth = 0, FloorVoidOffset = 0, CeilingVoidOffset = 0;
        Document doc = Application.DocumentManager.MdiActiveDocument;
        Database db = doc.Database;
        Editor edt = doc.Editor;
        PromptIntegerOptions Prompt1 = new PromptIntegerOptions("")
            Message = "\nEnter Number Of Risers : Between 3 - 6",
            UpperLimit = 6,
            LowerLimit = 3,
            AllowNone = false
        PromptIntegerResult promptIntegerResult = doc.Editor.GetInteger(Prompt1);
        if (promptIntegerResult.Status == PromptStatus.OK)
            Risers = promptIntegerResult.Value;
        PromptIntegerOptions Prompt2 = new PromptIntegerOptions("")
            Message = "\nEnter Riser Width : Between 2000 - 5000",
            UpperLimit = 5000,
            LowerLimit = 2000,
            AllowNone = false
        promptIntegerResult = doc.Editor.GetInteger(Prompt2);
            RiserWidth = promptIntegerResult.Value;
        PromptIntegerOptions Prompt3 = new PromptIntegerOptions("")
            Message = "\nEnter Number Of Floors : Between 3 - 25",
            UpperLimit = 25,
            LowerLimit = 3,
            AllowNone = false
        promptIntegerResult = doc.Editor.GetInteger(Prompt3);
            Floors = promptIntegerResult.Value;
        PromptIntegerOptions Prompt4 = new PromptIntegerOptions("")
            Message = "\nEnter Distance Between Floors : Between 5000 - 9000",
            UpperLimit = 9000,
            LowerLimit = 5000,
            AllowNone = false
        promptIntegerResult = doc.Editor.GetInteger(Prompt4);
            FloorHeigth = promptIntegerResult.Value;
        using (Transaction acTrans = doc.TransactionManager.StartTransaction())
            BlockTable bt = acTrans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
            BlockTableRecord btr = acTrans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
            int Offset = 1500;
            int SlabDepth = 400;
            int SlabLength = 6000;
            int OutterSlabLength = 9000;
            Polyline p3 = new Polyline();
            p3.AddVertexAt(0, new Point2d(OutterSlabLength + (RiserWidth), Offset), 0, 0, 0);
            p3.AddVertexAt(1, new Point2d(OutterSlabLength + (RiserWidth), SlabDepth + Offset), 0, 0, 0);
            p3.AddVertexAt(2, new Point2d(OutterSlabLength + RiserWidth + (SlabLength), SlabDepth + Offset), 0, 0, 0);
            p3.AddVertexAt(3, new Point2d(OutterSlabLength + RiserWidth + (SlabLength), Offset), 0, 0, 0);
            p3.Closed = true;
            btr.AppendEntity(p3);
            acTrans.AddNewlyCreatedDBObject(p3, true);
            int nColumns = Risers-1;
            int dColumnOffset = RiserWidth+6000;
            double dArrayAng = 0;
            Matrix3d curUCSMatrix = doc.Editor.CurrentUserCoordinateSystem;
            CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
            Vector2d acVec2dAng = new Vector2d(curUCS.Xaxis.X,
                                                        curUCS.Xaxis.Y);
            dArrayAng = dArrayAng + acVec2dAng.Angle;
            Extents3d acExts = p3.Bounds.GetValueOrDefault();
            Point2d acPt2dArrayBase = new Point2d(acExts.MinPoint.X,
                                                        acExts.MaxPoint.Y);
            DBObjectCollection acDBObjCollCols = new DBObjectCollection();
            acDBObjCollCols.Add(p3);
            int nColumnsCount = 1;
            while (nColumns > nColumnsCount)
                Entity acEntClone = p3.Clone() as Entity;
                acDBObjCollCols.Add(acEntClone);
                // Caclucate the new point for the copied object (move)
                Point2d acPt2dTo = PolarPoints(acPt2dArrayBase,
                                                    dArrayAng,
                                                    dColumnOffset * nColumnsCount);
                Vector2d acVec2d = acPt2dArrayBase.GetVectorTo(acPt2dTo);
                Vector3d acVec3d = new Vector3d(acVec2d.X, acVec2d.Y, 0);
                acEntClone.TransformBy(Matrix3d.Displacement(acVec3d));
                btr.AppendEntity(acEntClone);
                acTrans.AddNewlyCreatedDBObject(acEntClone, true);
                nColumnsCount = nColumnsCount + 1;
            Polyline p1 = new Polyline();
            p1.AddVertexAt(0, new Point2d(0, Offset), 0, 0, 0);
            p1.AddVertexAt(1, new Point2d(0, SlabDepth + Offset), 0, 0, 0);
            p1.AddVertexAt(2, new Point2d(OutterSlabLength, SlabDepth + Offset), 0, 0, 0);
            p1.AddVertexAt(3, new Point2d(OutterSlabLength, Offset), 0, 0, 0);
            p1.Closed = true;
            btr.AppendEntity(p1);
            acTrans.AddNewlyCreatedDBObject(p1, true);
            Polyline p2 = new Polyline();
            p2.AddVertexAt(0, new Point2d(OutterSlabLength + ((RiserWidth + SlabLength) * nColumns + RiserWidth), Offset), 0, 0, 0);
            p2.AddVertexAt(1, new Point2d(OutterSlabLength + ((RiserWidth + SlabLength) * nColumns + RiserWidth), SlabDepth + Offset), 0, 0, 0);
            p2.AddVertexAt(2, new Point2d(OutterSlabLength + ((RiserWidth + SlabLength) * nColumns + RiserWidth) + (OutterSlabLength), SlabDepth + Offset), 0, 0, 0);
            p2.AddVertexAt(3, new Point2d(OutterSlabLength + ((RiserWidth + SlabLength) * nColumns + RiserWidth) + (OutterSlabLength), Offset), 0, 0, 0);
            p2.Closed = true;
            btr.AppendEntity(p2);
            acTrans.AddNewlyCreatedDBObject(p2, true);
            double nRows = Floors;
            double dRowOffset = FloorHeigth;
            // Set a value in radians for 90 degrees
            double dAng = Math.PI / 2;
            // Track the objects created for each row and column
            DBObjectCollection acDBObjCollLvls = new DBObjectCollection();
            acDBObjCollCols.Add(p1);
            acDBObjCollCols.Add(p2);
            foreach (DBObject acObj in acDBObjCollCols)
                acDBObjCollLvls.Add(acObj);
            // Create the number of objects for each row
            foreach (Entity acEnt in acDBObjCollCols)
                int nRowsCount = 1;
                while (nRows > nRowsCount)
                    Entity acEntClone = acEnt.Clone() as Entity;
                    acDBObjCollLvls.Add(acEntClone);
                                                    dArrayAng + dAng,
                                                    dRowOffset * nRowsCount);
                    nRowsCount = nRowsCount + 1;
            Polyline p4 = new Polyline();
            p4.AddVertexAt(0, new Point2d(OutterSlabLength, 0), 0, 0, 0);
            p4.AddVertexAt(1, new Point2d(OutterSlabLength, (Offset * 2) + (FloorHeigth) * (Floors - 1) + SlabDepth), 0, 0, 0);
            btr.AppendEntity(p4);
            acTrans.AddNewlyCreatedDBObject(p4, true);
            Polyline p5 = new Polyline();
            p5.AddVertexAt(0, new Point2d(OutterSlabLength + RiserWidth, 0), 0, 0, 0);
            p5.AddVertexAt(1, new Point2d(OutterSlabLength + RiserWidth, (Offset * 2) + (FloorHeigth) * (Floors - 1) + SlabDepth), 0, 0, 0);
            btr.AppendEntity(p5);
            acTrans.AddNewlyCreatedDBObject(p5, true);
            acTrans.Commit();
            doc.SendStringToExecute("._zoom _all ", false, false, false);
Replies (0)
