polyline simplification
mttlp
mttlp
hi;
simplification of multi-point drawn polyline
How do you remove the vertex from a polyline?
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
namespace IterateObjects
  public class Commands
    [CommandMethod("PLN")]
    static public void ListVertices()
      Document doc  Application.DocumentManager.MdiActiveDocument;
      Editor ed = doc.Editor;
      Database db = doc.Database;
      PromptEntityResult per  ed.GetEntity("Select a polyline");
      if (per.Status == PromptStatus.OK)
        Transaction tr = b.TransactionManager.StartTransaction();
        using (tr)
          DBObject obj = tr.GetObject(per.ObjectId, OpenMode.ForRead);
          Polyline lwp = obj as Polyline;
          if (lwp != null)
            int vn = lwp.NumberOfVertices;
            for (int i = 0; i < vn; i++)
              Point2d pt = lwp.GetPoint2dAt(i);
			// delete vertex
			//How do you remove the vertex from a polyline?
          tr.Commit();
Accepted solutions (3)
_gile
You can use the Polyline.RemoveVertexAt() method.
Gilles Chanteau
GileCAD
GitHub
mttlp
hi gile thank you
couldn't find the vertex between you can help me
_gile
You can try something like this:
        [CommandMethod("TEST")]
        public static void Test()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var options = new PromptEntityOptions("\nSelect Polyline: ");
            options.SetRejectMessage("\nSelected entity is not a Polyline.");
            options.AddAllowedClass(typeof(Polyline), true);
            var result = ed.GetEntity(options);
            if (result.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                Vector2d? vector = null;
                var pline = (Polyline)tr.GetObject(result.ObjectId, OpenMode.ForWrite);
                for (int i = 0; i < pline.NumberOfVertices; i++)
                    var segmentType = pline.GetSegmentType(i);
                    if (segmentType == SegmentType.Coincident)
                        pline.RemoveVertexAt(i--);
                    else if (segmentType == SegmentType.Line)
                        var direction = pline.GetLineSegment2dAt(i).Direction;
                        if (vector.HasValue && vector.Value.IsCodirectionalTo(direction))
                        else
                            vector = direction;
                    else
                        vector = null;
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
mttlp
thank you so much Gile
