Polyline 2D Create
Polyline 2D Create
k005
Advisor Advisor
Message 1 of 14
Polyline 2D Create
k005
Hello everyone
I am creating a polyline from the points in the datagridview.
The problem is ;
ucs draws a polyline from where the icon is...
I want to do; it just draws the given coordinates... how should I change that. ?
so it should draw from the first coordinate...
Thanks in advance for the help friend.
  acPoly.AddVertexAt(acPoly.NumberOfVertices, ikiDpoint, 0, 0, 0);
Replies (13)
Message 2 of 14
hippe013
@k005 You need to provide more information.
Okay, I am assuming you are using some sort of form. Need to know more about your dataGridView.
Do you mean that it is drawing from 0,0? Or that one of the points is 0,0? Or what icon are you referring to?
Need to see more than just the one line of code that your provide.
Message 3 of 14
GeeHaa
I'm not exactly sure what you're trying to do but I usually draw a polyline similar to below. Just extrapolate for you're own needs.
acPoly = new Polyline();
acPoly.SetDatabaseDefaults();
acPoly.AddVertexAt(0, new Point2d(ptStart2.X, ptStart2.Y), 0, wid, wid);
acPoly.AddVertexAt(1, new Point2d(ptStart2.X + border2X, ptStart2.Y), 0, wid, wid);
Message 4 of 14
k005
@hippe013
@GeeHaa
I am sorry. The question was a bit rushed.
I explain in the attached pictures.
Message 5 of 14
k005
I will try this. I have to go now...
Message 6 of 14
kerry_w_brown
@k005
To avoid this thread becoming a waste of effort and bandwidth you should post your code (relevant complete portion) along with a description of your expectations.
This way your peers will have an unambiguous starting point for helping you.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 7 of 14
kerry_w_brown
Perhaps something like this will give you some ideas :
Note this is proof of concept, without error checking etc.
[CommandMethod("DrawPline")]
public void TestDrawPline()
   Document doc = AcadApp.DocumentManager.MdiActiveDocument;
   Database db = doc.Database;
   Editor ed = doc.Editor;
   Point2dCollection point2Ds = new Point2dCollection()
      new Point2d(216, 230),
      new Point2d(478, 230),
      new Point2d(478, 85),
      new Point2d(216, 84)
   using (var tr = db.TransactionManager.StartTransaction())
      // Open Model space for write
      var dbBlockTable = (BlockTable)tr.GetObject(
         db.BlockTableId, OpenMode.ForRead);
      var msBlockTableRecord = (BlockTableRecord)tr.GetObject(
         dbBlockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
      var pline = DrawPolyline(point2Ds, 0);
      pline.Closed = true;
      msBlockTableRecord.AppendEntity(pline);
      tr.AddNewlyCreatedDBObject(pline, true);
      tr.Commit();
public static Polyline DrawPolyline(Point2dCollection pts, double width)
   var pline = new Polyline();
   pline.SetDatabaseDefaults();
   for (int i = 0; i < pts.Count; i++)
      pline.AddVertexAt(i, pts[i], 0, width, width);
   return pline;
Message 8 of 14
k005
@kerry_w_brown  Here is the whole code.
 private void btnKordinatCiz_Click(object sender, EventArgs e)
            this.Hide();
            Aapp.Document acDoc = aCap.DocumentManager.MdiActiveDocument;
           Database acCurDb = acDoc.Database;
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
            using (Aapp.DocumentLock docLock = Adoc.LockDocument())
                BlockTable acBlkTbl;
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, Adb.OpenMode.ForRead) as BlockTable;
                BlockTableRecord acBlkTblRec;
                acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], Adb.OpenMode.ForWrite) as BlockTableRecord;
                Polyline acPoly = new Polyline();
                var noktalar = new List<Point2d>();
                foreach (DataGridViewRow dgvr in dataGridView1.Rows)
                    var x = Convert.ToDouble(dgvr.Cells[1].Value);
                    var y = Convert.ToDouble(dgvr.Cells[2].Value);
                    var z = Convert.ToDouble(dgvr.Cells[3].Value);
                    var point = new Point3d(x, y, z);
                    var ikiDpoint = new Point2d(x, y);
                    noktalar.Add(ikiDpoint);
                    using (var acPoint = new DBPoint(point))
                        acBlkTblRec.AppendEntity(acPoint);
                        acTrans.AddNewlyCreatedDBObject(acPoint, true);
                        //acPoly.ColorIndex = 1;
                        //acPoly.Closed = false;
                        //acPoly.AddVertexAt(acPoly.NumberOfVertices, ikiDpoint, 0, 0, 0);
                        //acPoly.AddVertexAt(0, new Point2d(point.X, point.Y), 0, 0, 0);
                acBlkTblRec.AppendEntity(acPoly);
                acTrans.AddNewlyCreatedDBObject(acPoly, true);
                acTrans.Commit();
                this.Close();
                aCap.SetSystemVariable("pdmode", 34);
                ZoomExtents();
Message 9 of 14
kerry_w_brown
I'm pretty sure, after you iterate through the dataGridView,  you could call a method similar to the DrawPolyline I posted that takes your list noktalar  instead of the  Point2dCollection  point2Ds that I used.
. . . or you could just add the code in-line to the body of your method  🙂
I like to separate functionality, mainly for testing, but there's no rule that says you have to.
Be sure to add a couple of debug breakpoints in your testing code and view the values in the critical variables in the 'Locals' pane at each breakpoint, ( or while stepping through the code )
Message 10 of 14
hippe013
It appears that the issue is that you are iterating through every row of the data grid view. The very bottom row is an empty row. That is where you are creating the point at 0,0 and adding it to your polyline. Does this appear to be the case? You may want to test for that bottom row so that it doesn't get added.
Message 11 of 14
k005
So how can I remove the last empty datagridview1 row?
Message 12 of 14
hippe013
Instead of doing for each row...
Get the row count and minus one from it. (As long as you are certain that the grid will always contain an empty row.) Then use a simple for loop.
Message 13 of 14
kerry_w_brown
Perhaps try
(untested, may require test for null or string.empty  on cells.)
   if (dgvr.IsNewRow) {continue;}
   //else read cells
added:
Have you actually set a debug breakpoint to check the value of noktalar  or stepped through the foreach in debug to actually see what is happening ??
added:
I assume you are handling the DataGrid as part of your process.
If so, perhaps remove empty rows before saving/proceeding.
eg: https://codepedia.info/delete-empty-null-rows-datatable   (thanks mrs google )
Message 14 of 14
k005
Thank you very much. Ok. 🤗
@kerry_w_brown
@hippe013
@GeeHaa
