Passing point to command and getting results programmatically using c#
Dear all.
I want to call the command(e.g. LABCOOR or LABLAT) programmatically using:
doc.SendStringToExecute("LABLAT\n", false, false, false);
or
ed.Command("LABLAT");
or any other way.
Running this command requires user to pick a point. Is there a way to automate point selection?
And other question: is there a way to get results of a command programmatically as well?
Is that correct approach at all?
My problem in general: get lat/long values of a point to handle them later.
Thanks in advance.
_gile
@Anonymous wrote:
Dear all.
or
or any other way.
Assuming the point is (20, 10,0)
doc.SendStringToExecute("LABLAT 20,10,0\n", false, false, false);
//or
ed.Command("LABLAT", new Point3d(20.0, 10.0, 0.0));
A command cannot return a value but you can store some value in a member of your class.
Gilles Chanteau
GileCAD
GitHub
//or
Thanks for your reply!
So, that means that I could pass point coordinates to a command. But how do I get it's results? I mean not on the plot, but programmatically?
I guess I could look for newly added elements and get text values there, but I feel that there should be a better way to do it.
_gile
A method decored with the CommandMethod attribute cannot have arguments and cannot return a value.
So you have to use a work around with some side effect to "get the command results".
As said before, you can have some member (field or property) in the class where the command is defined and set their values from the command method.
Gilles Chanteau
GileCAD
GitHub
