Netload doesn't work in AutoCAD script ( but works when I manually typing it in command line)
soonhui
Advisor Advisor
soonhui
Here's something strange. When I explicitly type in Netload at the AutoCAD command line, I can select the relevant dll and the loading is successful.
However, when I netload it via script, it doesn't work.
To be more specific, I'm launching AutoCAD 2023( as Civil 3D 2023, but it shouldn't matter here) as a Debugging action in my Visual Studio 2023, with the following command line argument:
/ld "D:\Program Files\Autodesk\AutoCAD 2023\\AecBase.dbx" /p "<<C3D_Metric>>" /product "C3D" /b "C:\Users\User\Documents\Projects\MES\MiTS2\Civil3DIntegrator\Source\LoadPlugin_2023.scr"
And in my SCR script, this is what I put in
netload "C:\Users\User\Documents\Projects\MES\MiTS2\Civil3DIntegrator\Source\bin\Debug\2023\MES.Civil3DIntegrator.dll"
When I launch my debugger, I can see AutoCAD being loaded alright, but I don't see my plugin being activated ( like I mentioned above, if I manually type in Netload then everything works just fine). When I press F2, I got this weird message:
netload Assembly file name: "C:\Users\User\Documents\Projects\MES\MiTS2\Civil3DIntegrator\Source\bin\Debug\2023\MES.Civil3DIntegrator.dll"*Cancel*
*Cancel*"C:\Users\User\Documents\Projects\MES\MiTS2\Civil3DIntegrator\Source\bin\Debug\2023\MES.Civil3DIntegrator.dll"
Notice that AutoCAD actually cancels (??) my netload, for unknown reasons!
On a separate note, notice that the dll is located 2 directories below the .scr file. I wonder whether it's possible to simplify the scr content  to something like
netload "..\bin\Debug\2023\MES.Civil3DIntegrator.dll"
Does SCR file support relative path?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
ActivistInvestor
Have you tried using the LISP (command) function to invoke NETLOAD?
soonhui
@ActivistInvestor , no haven't. But can you call .lsp file like how you call .scr file in the VS debugging command line setting?
Ngu Soon Hui
_gile
In the script file, replace:
with this LISP expression:
(command "netload" "C:\\Users\\User\\Documents\\Projects\\MES\\MiTS2\\Civil3DIntegrator\\Source\\bin\\Debug\\2023\\MES.Civil3DIntegrator.dll")
Gilles Chanteau
GileCAD
GitHub
soonhui
@_gile , this is what I got after modifying the SCR file:
Now the plugin is loaded and all I have to do further after this, is just to press the Enter key. There is some progress in a sense.
But why my original command couldn't work? It does work in other project though, but not this one.
And is there anyway to enhance the script still, so that I don't have to press Enter to load the plugin?
Ngu Soon Hui
_gile
In an AutoCAD script file, a space or a carriage return means 'Enter'.
Gilles Chanteau
GileCAD
GitHub
