.NET
Need help converting C# to VB.NET
8 REPLIES 8
Message 1 of 9
wouterbleumink
1393 Views, 8 Replies
Hello all,
I am a enthausiast and not a professional. I am used to wrting my code in VB.Net. Mostly this is not a problem as there are numerous C# to VB code-converters available on the web.
The code from the example in this article: Trough the interface: xref however does not convert correctly. For example the 'sub initialize' present's a problem for me.
Would it be possible for someone to post the VB.Net code for this topic?
Kind regards,
Wouter
8 REPLIES 8
Message 2 of 9
What's the problem you are having with the Initilize method?
Here's the stub of what it should look like:
Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
      'your code goes here
End Sub
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 3 of 9
in reply to: wouterbleumink
I always use this convertor. It's free and works like a charm.
http://converter.telerik.com/
Kind regards,
Irvin
Message 4 of 9
Thank you for your reply.
When converting the C# code, the sub Initialize looks like this:
	Dim dm As DocumentCollection = Application.DocumentManager
        ' Remove any temporary objects at the end of the command
	dm.DocumentLockModeWillChange += Function(sender As Object, e As DocumentLockModeWillChangeEventArgs) Do
        If _ids.Count > 0 Then
            Dim tr As Transaction = e.Document.TransactionManager.StartTransaction()
            Using tr
                For Each id As ObjectId In _ids
                    Dim obj As DBObject = tr.GetObject(id, OpenMode.ForWrite, True)
                    obj.[Erase]()
                Next
                tr.Commit()
            End Using
            _ids.Clear()
            ' Launch a command to bring across our layers
            If Not _placeOnCurrentLayer Then
                e.Document.SendStringToExecute("_.XOFFSETCPLAYS ", False, False, False)
End Sub
 The line marked red in the code above causes my headaches. My knowledge of C# to VB is limited and i don't know how to convert it.
Can you help me?
Thanx in advance,
Regards Wouter
Message 5 of 9
Which version of VS (VB.NET) you use? VS2010 or VS2008? Since you are doing AutoCAD programming, I assume you use VS2008 with .NET3.x, or VS2010 targeting .NET3.x.
In this case, VB.NET does not has good support as C# to anonymous method, which looks like in C#:
SomeObject +=(o, e)=>{....};
or
SomeOject += delegate(o,e){....};
In VB.NET2008, you just
AddHandler dm.DocumentLockModeWillChange, AddressOf DocManager_LockModeWillChange
Then you write a separate method
Private Sub DocManager_LockModeWillChnage(sender as Object, e As DocumentLockModeWillChangeEventArgs)
    'Do whatever you need to do to handle the event
End Sub
Yes, some C# to VB.NET converter does not do a good job on this kind of Lambda/Anonymous function/method conversion. (this makes C# programmer looks having a bit more edge the VBer :-().
Norman Yuan
Drive CAD With Code
Message 6 of 9
Norman's comments are correct, but since I was already doing it, and since figuring out what to move to a new function might be tricky, I have attached a text file with the code converted to VB.
Message 7 of 9
Thank you Norman and Chiefbraincloud.
I am using VB2008..
I will try the code submitted tomorrow..
Thanx again.
regards,
Wouter
Message 8 of 9
Message 9 of 9
Here is the converter I generally use:
http://www.developerfusion.com/tools/convert/csharp-to-vb/
Developerfusion.com is a good website in its own right. The addition of the converter just makes it more valuable.
Forma Design Contest
